18" Monoblocks
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
18" Monoblocks
I'm looking for a new set of 18" Monoblocks for my C43 (front and rear). Reps are fine with me as long as the quality is good. Does anyone have a lead?
Yup. I have regretted the 19” Mandrus rims since day 1. They look great but the ride leaves much to be desired. Plus I have always loved the Monoblock look.
on top of all that, my wife has curbed the rims and they look like crap.
I am planning on a refresh of the ‘ol C43 which includes head lights, turn signals, monoblocks, windshield, and either a wrap or new paint.
So so far I’ve installed the new windshield and turn signals.
I’m also going to finally do the 55 swap so I’m on the hunt for a motor as well.
PJ,
Yours look pretty flush. What is the ET and are you using spacers?
The ET varies depending on what Mono's you get. I've seen the fronts +30 - +32 and the rears +35 - +37. My current rims are 32 front and 35 rear. The front is almost slightly too much and the rear is not enough so I'm guessing +31 for the fronts and +37- +40 for the rear?
PJ,
PJ,
Just pulled the trigger on some reconditioned 18" monoblocks with 31 ET front and 35 ET rear. Gonna throw some PS4S on them
Any comments concerning the functionality of adding 18" or 19" old-school monoblocks to my 2007 CLS63 AMG currently running 20" low-pro wheels--although I raised the suspension full-tilt to avoid continued curb clashes...
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
You'll definitely want to check brake caliper clearance as the calipers on the CLS63 are much larger than any of the sliding calipers found on the cars that came from the factory with Monoblocks.
I am running E55 Mono's that are Front: 18x8 et31 Rear: 18x9 et35 +10mm spacer and they are pretty flush. I had to have my rear fenders shaved down a bit because they were rubbing after I added the 10mm spacer though. Other than that it looks flush and perfect
Benzrider17 (11-15-2019)
'99 CLK/05 E500 WAG
2MERKS
