Cleaning windscreen storm drains
As the weather is ****ty these days with rain and coolish temperatures, I decided to work in the garage and check the water drain on the passenger side close to the fire wall. I have not had any issues with water ingress but better be preventive than reactive IMO
I removed all the lower windscreen trimmings so as to open all the area under the wiper and cabin air intake (see 1st photo). All the parts were then washed with some soapy water and a soft brush.
Looking down into the corner of the cavity, there was some small leaves and debris (2nd photo). That was quickly vacuumed out. Then onto the rubber drain with a flap on the outside to check it was dirt free. How to poke around down there?
Easy, took my flexible transmission dip stick and pushed it in and out a couple of times to make sure all is clean (3rd photo). Perfect.Reassemble everything making sure all the trimmings are clipped and screwed down, job done. BTW when you are doing this, why not consider removing the turtle cover from the wiper arm and lubricate with water proof grease. Job done
All the trimmings removed, then washed in soapy water before reassembling.
Some small debris and nothing major. The drain hole can be seen in the lower right of the trough. Guess that speaks for having the vehicle in a closed garage and not parked under trees
Transmission dip stick. Perfect poking tool. Just make sure you clean it before inserting in your transmission
Btw the windshield wiper covers and whole arm are fairrly inexpencive new. Im considering ordering since its nearly impossible to clean the old stuff to perfection
I forgot to ask, did you also have to remove the long rubber weather seal that goes from end to end when you removed the top covers?
