Talk me into buying a C36 AMG....
So a little background. I currently own a 99 C280 (since 2015) that I LOVE...but she is starting to rust bad on some spots and mechanically, she runs close to perfect but has issues once in a while with a misfire CEL that I can't quite figure what it is....
I sitll love the pep of the car and look. The engine is built like a TANK also.
I was thinking of moving on to a c36 AMG because I love the body style so much. Moving from my 99 to a C36, would you recommend it or caution against it? How is maintenance for this car? Finding parts? Is it interchangeable with the c280? Like Motor Mounts for example.
What issues should i look for if I do get more serious in buying one? Oil leaks? How hard is maintenance with changing plugs? I know with the design of the C280 it was a pain in the ***. Anything else you can think of?
Also, what's the going price for c36s?
Thank you in advance, guys!
All engine parts, at least external add ons are the same(plug wires, coil packs, water pump, pulleys.....)
C36 is more of a sensitive car and is less reliable but still a very good care f taken care of.
C36 is the one to get right now as its becoming more ad more desirable.
Either way you go you wont regret it. C43 is a little more forgiving so you wont have to look for a perfect one.
When buying a c36 on the other hand, make sure its been taken care of because youll have to deal with some expensive things such as blown head gasket, chewed through wiring harness. Both of these are expensive to fix.
Thats what hat I am thinking. My fear is any type of little issues though and the cost.
I found a 97 with 180kish miles. With that much mileage what should I be looking for if I go check this car out?
I am looking specifically at a 97.
First generation 722.6 - 5 speed electro for 1997 C36 is temperamental same goes for the 98 C43!
You have to find out if trans has been repaired or not?
If you like the car and like to work on it just make sure you know what you are buying and how much work itll need
MB updated the design with stronger bearings when they found out they had a poorly designed transmission.
MB always had strong hydraulic gearboxes, why make a weak electronic gearbox then not test it properly?
Even the W124 E/CE/T36 AMG suffered from 5 speed electronic gearbox.
I was in the market for this car before I got my C43.
When people bought an automatic they want more gears for lower fuel consumption and top speed, W124 with Sportline package came with 5 speed automatic , in this case would have preferred buying a car with a 4 speed auto.
5 speed were weak and troublesome!
I have seen lots of C43's on german Mobile site, where it says ATG in the ad which stands for replacement gearbox.
There's definatelly something fishy going on with the 722.6xx trannies.
Even the British MB magazine buyers guide warns about these trannies to check them out before purchase of a car?
I recall that W124 500E/E500 had some issues with their trannies but I don't remember what their problems was?
Can you tell what their culprit was?
I was also in the market for an E500 but decided not to buy such car coz it only had 4 speed.
