w202 max tire size on 18"
245/45/17 = 1971 mm circumference with sidewall height of 99mm
255/35/18 = 1996 mm circumference +1.2% and sidewall height of 89mm -10.3% over the 245/45/17 tyre
265/35/18 = 2019 mm circumference +2.4% and sidewall height of 94mm -5.1% over the 245/45/17 tyre
275/35/18 = 2040 mm circumference +3.6% and sidewall height of 97mm -2.6% over the 245/45/17 tyre
Keep in mind that your speedo will indicate a lower speed than actual speed so bear that in mind when speed limits apply.
@DRBC43AMG speed limits, what’re those lol?
but thank you for those conversions! I’m most concerned about the fronts rubbing when turning if I run 245/40 up there. Any thoughts? Thanks
@MattCordell think a 245/40 rubs up front when cornering/turning tho?
will definatelly rub on tire inner shoulder.
it's cool having wide rims and tires, but it will slow your car down coz rims are heavier!
if your car is lowered, or having a very low profile on tires?
if you dislike harsh ride?
you will hate it!
most tires will rub if you go wider, recommended size is 225 front and 255 rear.
looks dope with this set up on 8,5/9,5 inch wheels.
wider tires up front which sticks out from wheel well will also cause damage to paint on your fenders as rocks and sand will sand blast your fenders.
think about this what could happen?
Car is at stock height on stock suspension tho. That's a good point about rocks and debris kicking into my fenders as a result of the wider tires, i didn't think about that. I may just try and run 275/35 in the rear then and buy a new set of 225/40 for the fronts. I guess spending $500 on tires right now is better than $1000... I'll throw the 18's on this week and report back
Car is at stock height on stock suspension tho. That's a good point about rocks and debris kicking into my fenders as a result of the wider tires, i didn't think about that. I may just try and run 275/35 in the rear then and buy a new set of 225/40 for the fronts. I guess spending $500 on tires right now is better than $1000... I'll throw the 18's on this week and report backwill definatelly rub on tire inner shoulder.
you will hate it!
@PJmak i have to think that i'll be ok with 245 if im sitting at stock height then. All good news, looks like i may not need different tires after all! I'll report back with some pics once i get a chance to swap the wheels this week.
Thanks for the help all!
your fronts do they stick outside the fenders?
do you have any paint damage?
if it works with 255 up front then cudos!
Probably was a cost issue or something?
Upper control arm with ball joint that pokes out towards the inner shoulder of the tire should clear any rubbing if used 245 or 255 tires up front?
However?
Lowered cars should probably face rub issues using wider tires than 225?
Or am I wrong?
