Auto start vs. hold key until starts
Old Apr 5, 2021 | 10:29 PM
x463's Avatar
1998 C43 w/ 55 swap Wavetrac LSD and 6-Speed manual
I don't know the correct term for this feature - which is probably why I can't find anything searching.
Car is a 1998 C43 (w/ 55 swap but that was 6000 miles ago and this problem is new.)
What I'm talking about is how the ignition key typically is twisted clockwise to the start position and then released - car will crank as much needed to start the car automatically.
Lately that is only working about 50% of the time. When it fails it will crank for a split second only. I then have to turn the key counter-clockwise and then back clockwise to start and HOLD until the engine starts.
The engine always starts and it starts with a normal amount of cranking...I just need to hold the key.
Battery is good.
Same result w/ a new key (couple months old) and original key
New crank position sensor (no change)
New cam position sensor (no change)
Any ideas? Doesn't look like a K40 relay issue based on what I've read.
Old Apr 6, 2021 | 02:04 AM
PJmak's Avatar
Theres a small window underneath on the trans. Grease up the gears in there.
Old Apr 6, 2021 | 03:14 AM
DRBC43AMG's Avatar
What grease do you use to apply to the cogs?
Old Apr 6, 2021 | 07:03 AM
x463's Avatar
You are talking about the ring gear on the flex plate?
Old Apr 6, 2021 | 10:21 AM
PJmak's Avatar
Yep. I had it done once or twice and it seemed to have resolved the issue.
Old Apr 6, 2021 | 10:22 AM
PJmak's Avatar
Honestly I dont remember but im sure anything will work
Old Apr 7, 2021 | 10:31 AM
BVC500's Avatar
2016 GLC300 & 1991 500SL
Could be your electronic ignition switch going bad? Do you hear a click when you put the key in and take it out? Mine went bad and had to be replaced.
Old Apr 8, 2021 | 10:50 AM
x463's Avatar
Not sure about the click. Will pay more attention. Is that an expensive dealer only repair w/ Star programming?
Old Apr 8, 2021 | 01:38 PM
BVC500's Avatar
Yes, mostly likely has to be done by the dealer. If I recall correctly, it was around $300.
