C43 vs C32 Brakes
-s-
Exactly!
The brake caliper will fit just fine but the leading edge is wrong with the C32 brake caliper. The piston size of the leading piston is normally sized differently than the second piston. This effects the way the brakes bite when they are first applied. I would stick with stock or just go with a set of stoptechs (brembo like but less money).
As for the brakes changing color, this happens to all large brake kits with painted calipers. I have seen brembo bbk's, stoptechs, Porsche brakes, and Brabus (painted calipers) all with a mucky dark bronze finish. Red 996 brakes turn brown while silver StopTechs turn a nice dark bronze. This all has to do with how hard you drive and the normal driver will never push their car hard enough to induce this color shift. It just happens...I call it a sign of "I use my
