Just purchased a WAVETRAC LSD, a couple questions
Old Aug 25, 2021 | 07:01 PM
S6TEN's Avatar
99 C43
Hello AMGZ
I just ordered a Wavetrac LSD
I would like to ask is what parts should I replace with it,I've read that the bearings are a must for sure, I would normally do something like this myself, but want to be honored with the warranty, so I plan on having all the parts available for when I take it to a reputable shop. I have attached the EPC components hoping the knowledgeable can pick some numbers for me.
If there is any other variable that I may be missing, please let me knw. My plan is to make this go by as smooth as possible.
Thank you
Old Aug 28, 2021 | 01:11 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
bump? I'm also going to purchase an LSD in the future, would love to see this thread fulfilled
also, where'd you get your wavetrac and how much was it?
Old Aug 29, 2021 | 01:32 PM
S6TEN's Avatar
99 C43
hey man, thanks, go it from Dana port.com, came to like 1k with the 10 percent off they had going.
Old Sep 1, 2021 | 07:47 AM
x463's Avatar
1998 C43 w/ 55 swap Wavetrac LSD and 6-Speed manual
I replaced all the seals, bearings, and bushings/mounts when doing mine. Adds up in a hurry but as mine had 200K miles it wasn't worth skimping out. I've got about 6K miles on the 5.4 and Wavetrac now.
Old Sep 1, 2021 | 12:21 PM
"714guy"'s Avatar
Thanks for the Link.. newb question.. Is this the model for the c43s? - Wavetrac LSD
Please keep us updated with your progress...
Old Sep 1, 2021 | 12:31 PM
x463's Avatar
No - the 210 is bigger and won't fit. You need the one that is more typically advertised for a Chrysler Crossfire or SLK. It's part # 48.309.175WK.
FYI - there is a slight modification to the flanges required.
See here:
https://autotech.com/images/F198644058
Old Sep 1, 2021 | 01:39 PM
"714guy"'s Avatar
Thank you!!
Old Sep 2, 2021 | 09:49 PM
Quant's Avatar
2002 CLK55
See here:
hi, can you please provide more info on this modification.
thanks
Old Sep 10, 2021 | 10:20 PM
brad_c43's Avatar
'99 C43, '88 560SL
FYI, I did no modifications and I didn't replace anything and have done 10s of thousands of miles no issue
