C1512 ETS brake fault code
After some hard braking on race track, it appears this fault code and ETS lights on for some seconds. I guess that durind this time ABS is off.
Do you have some experience with this type of problem?
Any informations will be useful.
Best regards,
C1512 w202 ets fault brake
If you are tracking the vehicle, I would recommend some harder pads AND some high temperature brake fluid. When did you flush the brake fluid? Also, when tracking you need to purge the brakes very regularly (each day) to eliminate air bubbles.
If the brake switch is faulty (cheap and quick fix) it does have some strange influences on ABS, ETS, tempomat, etc.
After I delete, the problem appears again.
I use Ferodo Racing DS2500 pads and Motul Racing brake fluid, 660.
The whole system is properly set for racing only the ABS module and ABS command unit is stock as factory buid. So I think this is the problem and I try to find a way to trick it
I've never seen something like that
our dolls uses (5-123C ESP/965) Bosch pressure sensor, which is very sensitive about fluid temp range..!,
when you use sporty/thicker oil, and start screaming,
ESP/BAS pressure sensor will detected the differ fluid viscosity, and send the H/T signal it to the ESP/ECU brains..
no worries, nothing will happen to the brake system, it's a matter of heat monitoring, and ECU want to prank you..
-;-ZAYED-;-
https://mbworld.org/forums/c36-amg-c...-location.html
but no need to replace it, it's a matter of code that stored to the ECU/ESP modules,
if you don't want that code to show up, you will have to upgrade all ESP/BAS + M/C + booster from "W220 or R230",,
i'm always doing that with any brake upgrade, but it's really not necessary if your current brakes performs well..
-;-ZAYED-;-
