Hey everyone , just need some help on removing the front doors.
I searched google and did not find much accept removing the panels.
I want to know how to disconnect all the wires so I can pull the door off.
One guy disconnected all the wires from the door itself which seems unreasonable for Mercedes to design it that way.
For the w210 there’s connections where you can unplug inside the plastic cover on the inside of the car.
Is this the same for our C43 cars? I would check but it’s cold outside and my car is very well covered up for winter.
Thanks for any advice.
Hi George,
I don't know the answer to your query, but I think that probably there must be a connector behind the panel trim on the inside of the vehicle. I would search there first.... Good luck
I dont remember there being a plug. There are wired that you need to feed through the door to remove the door. You have the speaker, airbag, and deat adjustment wires. Not too bad at all. Also need to disconnect the door stop. Its fairly easy.
Yeah definitely not hard but I was hoping I didn’t have to do all that. Thanks.
Came across this YT video showing how and where to disconnect the electrical socket from the door. Hope this helps https://www.youtube.com/watch?v=TH85kE5TdHc
A quick search using "How to remove W202 front door" also came up with plenty of videos to watch....
I saw that before but my c43 does not have that hole to insert the tool.
