C 36 Temperature ????
Mercedes Dealers in my city checked the car and they say it is normal, is that OK?? or do I have to do something to fix it???
please help me!!!!!!!
a little more info as where you live ..? climate...? when the last time you do a coolant flush ?, replacing thermostat ?
would help.
My car never run exceeded 90 mark.
Regardz,
J Irwan
Just make sure that the aux fan is working well.Mine just gave up 2 months ago overheated and killed the radiator.
The merc engine is amazing though.Not damaged in any way.Compression / leak down tests were fine.
My Merc mecahnic said it is only the second C36 he has seen overheat.Mine has 180K km on the clock though.
Good luck.Don't worry about it straying to 100 provided it comes back down.
I live in Mexico and the temp in my city is 25-30c, so is no to hot, the car has 80k Miles, and the services were made in Mercedes, When i took the car to mercedes to check the temp ¨I think¨ they check te thermosat and the coolant, and also they did the compression test and is ok. The aux fans kick in around 100C. Im not sure about the fan clutch. how can I check it ?
What do you think about all this things????
I have another question...
My car was prepared for Mexico´s gas for the year 95.( 87 octanos) and has 260hp. Now we have 92 octanos gas, so if I put powerchip I think I gain around 40HP is that right?????
Thanks a lot
If you don't get the roar then the viscous coupling isn't working as well as it should.
The other thing is, does the temp seem to move up and down quickly? An example would be if you stop at a set of traffic lights, will the temp go up 10-15C before you move off?
If so then you may have a partial blockage of the radiator which causes the coolant to pass through the remaining tubes too quickly which doesn't let it cool down enough so the aux fans cut-in more often.
