c43 Performance exhaust vs AWE tuning exhaust c450
the crackles are controlled by the ECU. so the amount should be about the same but it should be much louder.
also there is two styles Track and touring. so if you go the track version you are eliminating the rear muffler and basically getting strait pipes. so its going to be much louder.
I think you'd be happy with either option, though.
Awe-switch path exhaust works like your normal exhaust. Comfort is still quiet but you can open it up in sport+. I have the 63s with the track exhaust so iits always loud and cant be happier. Never want it quiet. personal preference I guess.
Question on your sport exhaust, is it in "loud" mode all the time or is there a button to activate it and silence it?
Thanks.
The C43 AMG Performance Exhaust is louder than the AWE, more rubble and more clips when just sitting there revving the engine. When you drive they both crack and pop. The biggest change is if you have the base exhaust, then the AWE will beat it hands down.
I'm selling my AWE Performance Exhaust in another post. I have also made a review on Youtube of the C43 AMG including the exhaust note for those that wanted to see the difference between the C450 AMG. I also state that the AMG Performance Exhaust is a must have on the C43 AMG.
Hope that helps.
Whatever what options you pick, PE has to be ticked no matter what. The car is soulless without it.
I made that mistake of buying car without it
https://mbworld.org/forums/c450-c43-...-complete.html
Did a retrofit which is awesome and sounds louder because the valves are always open.
