C450/C43 AMG
Front tyres feathering
Old May 6, 2017 | 06:12 AM
AMG-010's Avatar
2017 AMG C43
Wondering if anyone else has the same issue?
My car is only 2months old and only done 2,500km, I noticed today the tread on front tyres is very rough, like the wheel alignment is out and they're feathering quite badly, the rears are fine, any ideas?
Old May 7, 2017 | 05:11 AM
AMG-010's Avatar
2017 AMG C43
Anyone else experiencing this?
Old May 7, 2017 | 06:44 AM
alexasa's Avatar
c
I had a bit of this.
bent wheels and a bad alignment seemed to be the issue.
Old May 7, 2017 | 02:42 PM
Mr. J's Avatar
C450, GLC43
Get the alignment checked. It seems that a few cars make it through with improper alignment.
Old May 8, 2017 | 04:11 AM
AMG-010's Avatar
2017 AMG C43
Went to Dealer today and they said the Toe was more than likely out and suggested I get a wheel alignment but I have to pay $150 for it. Considering I paid $120,000 for the car only a couple of months ago don't think I should have to pay for it.
Old May 8, 2017 | 05:21 AM
alexasa's Avatar
c
stealership.
they should check it for free.
Old May 10, 2017 | 03:52 AM
Tuono's Avatar
What tyres are you running?
Out C43 came with Dunlop Sport Maxx RTs. We've done just over 5,000 miles and there's a definitely more wear and scrubbing on the outside of the tyres at the front.
Old May 10, 2017 | 04:00 AM
AMG-010's Avatar
2017 AMG C43
I have Continental ContiSport which were factory fitted.
Old May 10, 2017 | 10:34 AM
coladin's Avatar
2014 C63 507, 2012 R350
In Canada, MB covers alignment issues the first year or 20K. Maybe check up on that as you shouldn't have to pay on a new car in that window.
Old May 10, 2017 | 02:29 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
Went to Dealer today and they [PHP][PHP]said the Toe was more than likely out and suggested I get a wheel alignment but I have to pay $150 for it. Considering I paid $120,000 for the car only a couple of months ago don't think I should have to pay for it.
The vehicle is but two months old with only 2500 km. This is indicative it came from the factory out of alignment. In other words, a build error.
Unreasonable to expect the new owner to pay to correct a factory build error.
I've watched Corvettes coming off the line, at which time the final alignment is accomplished. Takes all of two minutes.
I would insist MB cover this cost just as they did for the noisy brakes.
Old May 10, 2017 | 03:36 PM
keninblaine's Avatar
2015 Macan S; 1996 911 C4S
My dealer (Porsche/Audi/VW) has a laser alignment system that takes about 5 minutes to do a check. They clamp alignment devices on each wheel, and then roll the car about 10 feet while a device mounted higher on a wall in front of the car calculates all the parameters for toe-in, camber, caster, etc. The least your dealer should do is check it for you free of charge. I agree with others that they should also correct it if it is out of spec. If they can't do that, they aren't very customer service oriented and I'd find another dealer next time (if available of course). Good luck.
Old May 11, 2017 | 05:22 AM
AMG-010's Avatar
2017 AMG C43
I agree with what you are all saying. If I really pushed it I could get it aligned no charge as I feel I am entitled to anyway as I haven't hit any pot holes.
I have just bought H&R springs so once installed will need an alignment anyway so will let it go
Old May 11, 2017 | 09:05 AM
Tuono's Avatar
Would be interested in your feedback on the H&R springs on the ride quality vs OEM.
Old May 11, 2017 | 11:46 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Do point out that OEM there is only ‘Toe’ adjustment front (and rear)!
OK if vehicle maintained and driven at showroom height, but day to day commuting encountering high cambered roads, altering/lowering height, load carrying, suspension sag, fitting wide profile tires or curb knock damage – the feature of having front and rear “ongoing Camber adjustment” to change tire “contact angle” is essential along with capability for extra Camber to reduce understeer/increase track width on Race days. With front Caster to “correctly resolve” steering pull and improve brake and steering response.
We saw the need therefore to design, manufacture and reinstate from the early ‘90’s kits that provide precise adjustment (on car under load direct on alignment rack). Also replacing the 4 front and 4 rear highest wearing suspension bushings at the same time. Result is no more ongoing trips to dealers or alignment shops or constantly changing tire brands. Fixing it right…. the 1st time!
For the front (only) you can purchase fluted bolts (not C63/S, S63/S65) – but they are inaccurate having ONE ONLY OFFSET POSITION, providing 3mm (1/8”) which is a minimal 0.3 degree change. The K-MAC patented design allows up to 3 times the adjustment range and is “precise accurate single wrench” adjustable.
Rear kits also provide Camber (and additional rear Toe adjustment to compensate for the new Camber facility). We do not manufacture rear Camber arms – as difficult to fit, access and adjust. Also to resolve premature inner edge tire wear need to reduce all important clearance top of tire to outer fender. Instead the K-MAC unique patented design precise single wrench adjustment system replaces the “lower arm inner bushes” moving base of tire inwards (or outwards to increase negative camber/track width). Comes with bush extraction tool allowing the Camber bushes to be installed on vehicle.
The front bushings are 2 axis/self aligning but without the oil and air voids of OEM. Result is noticeably improved brake and steering response. No modifications to fit – come with instructions and extraction/insertion tubes.
Also manufactured for the rear suspension is a full set of 12 replacement bushings for the 6 multi link arms. Providing significant improvement to rear end stability. Less flex/twitch, increased traction especially when applying power lane changing/overtaking.
W205
Front Camber and Caster
C400/C450/C43/S63 AMG 4matic #503216K $480
C63/S,S63/S65 AMG #503316K $480
Rear Camber (and extra Toe) #502226K $480
Rear multilink arms performance bush kit #502628K $480
Delivery $30 one kit or $50 front and rear (average delivery time is 3 to 4 days). We accept Visa, MasterCard or PayPal.
Front tyres feathering-502016-cover.jpg Front tyres feathering-502226-cover.jpg Front tyres feathering-501526-2-j-cover.jpg
