C43 Transmission update problem
I noticed that there was an software update, but I went to the dealer this morning and the computer show there is no software update for my car.
Does anyone knows the newest software number for the transmission?
Thanks a lot.
Here is the data sheet that I have got from the dealers, my car is 16/17 C43 Estate.
I posted this elsewhere...
I thought it was part of the transmission learning/breaking in process...but mine did it even at 2000 miles. Under hard acceleration, it would rev like I was on ice, slipping like a worn out clutch. 1st gear was the worst whether in manual or auto. Then, as you described rough shifting. I kept an eye on transmission temp as well. When cold it was worse. Even shifting from 3rd to 4th at redline it would slip badly. I too wondered if the tranny was done as my loaner C43 was perfect.
They did a software update and it is much better at shifting, not as "bang-bang", but still quick but properly smooth. Wait a bit but I'm sure you will need the update as many have
I'll add on top of that older post now that two thousand clicks later it continues perfectly fine and feels sturdy and robust. Very happy
When yiur our car was built may have to do with an update being available or not.
It made add a difference for me insoothness if shifts although it still doesn't always shift down to 1st at complete stops.
hopefully there is an update. outside of that random odd event, the car is a beast. loving it
