C450/C43 AMG
C450/C43 Wheel Fitment Guide
Rating: Thread Rating: 3 votes, 5.00 average.
Old 07-30-2022, 08:19 AM
  #901
alexasa's Avatar
c
Originally Posted by Synarchist
275/ 35 / 19
Will this be ok on a stock 19"?
Thanks.
no
Old 08-10-2022, 02:26 AM
  #902
jaydieu's Avatar
C43 AMG
I'm looking to purchase a set of 19" CLS winter wheels. Essentially they're the same turbine style as on a C class, but the specs are 19x8.5 et34.5 & 19x9.5 et48.
Based on what i've read, these should fit on my h&r spring lowered C43 coupe with maybe a 4mm spacer in front and 8mm spacer in the back? Theres currently Michelin winters 255/35/19 in front and 285/30/19 in the back, but i'm planning on getting the same size in summer performance tires.
Can someone just confirm that they would fit on my lowered C43 coupe, thanks
Old 08-10-2022, 08:13 AM
  #903
toosteeley's Avatar
Present: 2019 C43 Estate
^ Glad to hear you've read through this thread before asking
You're correct that a spacer will be needed in the front, but the closest you'll find is 3mm or 5mm (go with 5mm). Although you won't NEED spacers in the rear, 8mm would visually make the fitment better on a lowered car.
The challenge with that setup however, is the tire sizes. You'll never get a 255 in the front. Also, the aspect ratios are off for our cars. The ideal tires specs would be 235/40/19 and 275/35/19 (or 265/35/19).
jaydieu (08-10-2022)
Old 08-10-2022, 09:25 AM
  #904
jaydieu's Avatar
C43 AMG
I'm okay to run 235/40/19 & 265/35/19, but i'm trying to understand how @mo11 was able to pull off the setup that he ran. I know the only thing that might be different is his 10" wide in the rear running 295's.
5mm spacer making the front ET29.5 shouldn't rub either right?
Old 08-11-2022, 08:10 AM
  #905
toosteeley's Avatar
ET29.5 in the front with a 8.5" wide rim and 235/40/19 tires will be fine, yes.
There's much more tolerance in the rear, so yes, 295's are possible on a 10" wide rim and ET50ish offset. The challenge is matching the proper stagger in the front. Requires a number of other mods to get more than a 235 tire to fit without rubbing.
Old 08-11-2022, 09:29 AM
  #906
mo11's Avatar
2017 C43
I ran my set up for years (255/35 19 on 8.5 x 19 +30f) until i needed new front tires. I ordered the same size 255/35, when we installed it the wheel would NOT turn. Same brand same size, Michelin PS4s, only difference is the new tire was made in France and the older one here USA. I was so frustrated I ended up just getting 245/35 19 instead.
Old 08-11-2022, 07:14 PM
  #907
jaydieu's Avatar
C43 AMG
i thought you’re currently running 255 in front?
Regardless, I’m down to run ps4s 245 front and 275 rear, but I just need confirmation that its plug & play on an H&R lowered c43 coupe.
did you have any other mods/parts to assist dialling in your setup?
Old 08-11-2022, 07:38 PM
  #908
toosteeley's Avatar
245 in the front is risky. I have 235 PS4S with H&R springs (+31 offset) and can make it rub easily.
Old 08-11-2022, 07:45 PM
  #909
alexasa's Avatar
c
easy to run 245 on an 8 upfront. Which is the max tire width you should run on an 8. Fits stock and lowered at between et30 and et25, respectively
Old 08-12-2022, 08:31 AM
  #910
toosteeley's Avatar
^ on an 8" rim, sure. On an 8.5" rim, there's a high chance of rubbing. Not saying it can't be done.
Old 08-12-2022, 12:01 PM
  #911
mo11's Avatar
2017 C43
I used to for years with no issues, but a couple of months ago I had to switch to 245/35 because the 255/35 PS4s made in France was a hair wider than the ones made in USA. Keep in mind the aspect ratio is /35 not /40. Once my rear goes, I’ll probably switch to 285/30 which has a closer f/r ratio. But, 295/30 is still less than 1% difference f/r, so I might still stick with that for the rears.
I originally had H&R springs on the 255/30 f, then eventually changed to H&R VTF adjustable springs up front, and kept the rears on the H&R springs. Nothing else was done to the front other than a good 4 wheel alignment.
I’ve been thinking about getting k-mac camber kits too. For now I’m keeping it as is.
Good luck with your setup!
Old 08-15-2022, 04:13 PM
  #912
Sturdy43's Avatar
C43 amg 2019 sedan
Hey i am new to this
I have a c43 amg 2019 sedan i am on stock wheels but i wanna do 245/35 R19 front and 275/35 R19 in the rear i wanted to know if this set up will go fine i seen someone run 245/30 front but he running contintal extream contatx and I’m not able to look for them in the 30 they only have in 35 so i wanted to if it could run the setup thank you very much if anyone could help and I’m planning on running hr lowering springs to
Old 08-15-2022, 06:46 PM
  #913
Sturdy43's Avatar
C43 amg 2019 sedan
Helpooo
Originally Posted by NsxChris
Thanks Toosteeley,
I really appreciate the help and will change the rear tire to a 274/35/19 as you suggested!
did this set up worked fineeee whats offset front and rear please I’ll appricate it
Old 08-16-2022, 09:28 AM
  #914
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
@Sturdy43 Welcome to the forum. Maybe English is a second language for you? It helps the readers if you use punctuation in your post. https://www.thepunctuationguide.com/
Correct spelling also helps the reader understand your message easier. When typing a post, this website will underline misspelled words so you see you have something to correct.
Old 08-24-2022, 02:15 AM
  #915
jaydieu's Avatar
C43 AMG
@mo11 How did you get your camber dialed in so nicely? I just installed h&r sport springs and i have like -2.6/-2.9 degrees of camber in the rear. The fronts have -2.1 degrees, which is not perfect, but I'm complaining
Old 08-24-2022, 08:39 AM
  #916
mo11's Avatar
2017 C43
https://mbworld.org/forums/c450-c43-...ar-camber.html
post #16 w/ pic of which part to grind out
Old 08-27-2022, 07:11 AM
  #917
SPONSOR
K-Mac's Avatar
Mercedes-Benz CLK 550
For the C450 / C43 AMG we manufacture a “Total System” when it comes to resolving, costly, premature, edge tire wear. Or performance / track days improving traction in the pursuit of front row of the grid lap times.
OEM there is only Front and Rear ‘Toe’ (directional) adjustment. No Camber or Caster - essential to adjust tire contact angles, spread load more evenly to cater for other then showroom height conditions. High cambered roads, altered height, wide profile tires, curb knocks.
It’s all to do with cost cutting and ever increasing speed of auto assembly lines.
See spoiler re C450 / C43 AMG Bolt-on Kits:
Spoiler
AUDI to VOLVO - KMAC Experience Of Resolving OEM Suspension Shortcomings Since 1964!
Old 09-30-2022, 05:19 PM
  #918
Wesley_Fritz's Avatar
2018 Mercedes C46 AMG
Originally Posted by phillyAMG;[url=tel:8089425
8089425]i just got these wheels. Need et 30 for the front. And rears are et45. 8.5 front and 9.5 rears
Currently about to get this setup installed. Did you have to put on a spacer for the front inner lip of the tire to clear the control arm?
MaverickC43 (09-30-2022)
Old 09-30-2022, 10:34 PM
  #919
MaverickC43's Avatar
Amg C43
Never seen wheels like that.
they’re sharp!!
I just got a white c43
Always like seeing what people have
Mirrors look different.
Old 10-09-2022, 01:32 PM
  #920
skylashtravels's Avatar
2018 C 43 AMG
I've gone through most of the posts on this thread, but don't quite understand the wheel offset calculations.
On DiscountTire's site, it says that I can use either Front: 225/40R19 or 235/40R19 and on the Rear: 255/35R19 or 265/35R19 without any offset (spacers?) necessary.
My 2018 C43 isn't lowered.
I have the AMG 605 Multi-Spoke wheels:
Front:
Continental ExtremeContact DWS06
225/40ZR19 93Y XL
Rear:
Continental ContiSportContact 5P
255/35R19 96Y XL
Looking to change to the Continental ExtremeContact DWS06+ in a 235/265 setup, since I can't find the Michelin All Seasons in stock anywhere.
Could someone confirm whether this indeed would work?
Thanks!
Old 10-09-2022, 07:08 PM
  #921
alexasa's Avatar
c
Front:
225/40ZR19 93Y XL
Rear:
255/35R19 96Y XL
Thanks!
265 is not compatible on 8.5. Sure you can do it but you would be doing it for a performance downgrade. So don't.
There are studies that show a tire too wide for a rim actually reduces contact patch. You will have abnormal wear and you will be adding weight to each corner for less traction.
Run stock tire sizes on stock wheels.
Old 10-10-2022, 10:41 AM
  #922
2018 C 43 AMG
Thanks, I appreciate the input, I'll stick with the 255s
Old 11-03-2022, 11:10 PM
  #923
Louiscars190's Avatar
2019 Selenite Grey C43 AMG
How are 235/40R19 all around on 8.5 wheels?
Old 12-29-2022, 12:27 AM
  #924
yknblog's Avatar
2019 C43 Coupe
Hi everyone, my 2019 C43 coupe rims got cracked by a major pothole and am currently looking for a set of new rims. Could anyone please help me with a question that I have? Read through the thread and am unfortunately still very confused
My tire size (stock 19 inch)
Front: 19” 225/40-19
Rear: 19” 255/35-19
Will the rim sizes 8.5 Front & 9.5 Rear ET 35 cause any problems? Would I need spacers? Thanks!
Old 05-08-2023, 07:56 AM
  #925
jaydieu's Avatar
C43 AMG
Are there any 8mm spacer options that safely work with our car?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C450/C43 Wheel Fitment Guide
