C450/C43 AMG
C450/C43 Wheel Fitment Guide
Rating: Thread Rating: 3 votes, 5.00 average.
Old 08-09-2020, 01:38 PM
  #651
Nickkenny's Avatar
c43
I had concave rims 20 x 10 ET 48 and they stuck on the brake caliper.
Would I take 20 x9.5 ET 40 now would these fit?
isn't that too far from the original ET value?
Old 08-09-2020, 03:44 PM
  #652
VitaminJB's Avatar
C43 AMG
I can't recommend 20's for this car, but you should really contact the manufacturer before you spend that kind money on wheels. Concave does vary, plus you didn't specify whether it's the front or back...that makes a difference. There are a lot of knowledgeable people on here, probably some that have 20's, but consult the manufacturer and get a return guarantee before you buy them just in case they don't fit.
Old 08-10-2020, 11:42 AM
  #653
Nickkenny's Avatar
c43
In the back
Old 08-10-2020, 04:56 PM
  #654
Howyalivin's Avatar
Acura TL-SH, among others
Tmodelle, do you have a straight side pic of your car? I wanted to see what the wheels looked like from the side.
Old 08-12-2020, 05:55 AM
  #655
TModelle's Avatar
C190
Freder8d (08-12-2020)
Old 08-12-2020, 11:42 AM
  #656
Nickkenny's Avatar
c43
20 x 9.5 ET 40 now would these fit?
Old 08-12-2020, 12:23 PM
  #657
c43PDX's Avatar
C43 AMG
so after lowering the car, with 15mm spacers up front and wide shoulder max summer performance tires 225/40/19's on stock 19's (19x7.5 et33 -> et18) it rubbed like crazy.
I swapped to 12mm spacers up front and rubbing is minimal now (19x7.5 et33 -> et21).
I'm worried about going 19x8.5 et30 fronts not since they will poke out about 4mm more..
Anyone know if 19x8.5 et32~ clears the upper inner arms?
Old 08-12-2020, 02:39 PM
  #658
TModelle's Avatar
C190
The wheel will poke out more but your tire will be stretched more on the 8.5 and it should clear with no problem. There are many people running on 225 on 8.5 et30.
Many people run spacers with narrow wheels and forget about the tires.
In my opinion the car handles better with wider wheels so that you can get closer to the original offset, instead of using spacers and altering the offset.
Old 08-12-2020, 02:51 PM
  #659
Nickkenny's Avatar
c43
Tmodelle, do you have a picture from behind that i can see how far the wheel is
Old 08-12-2020, 06:30 PM
  #660
c43PDX's Avatar
C43 AMG
I was hoping that was the case with the mild stretch on the 8.5's. Yes tires come in such range of sizes, and the Max Performance types has such wide shoulders, I needed to go down 3mm on my spacers. I also rolled all my fenders in anticipation to an aggressive fitment. Currently my spring height is zero gap but tires are not tucking.
I'm looking at 19x8.5 et30 F and 19x9.5 et42 or 19x10 et48 R
Vertini RFS 1.3 or AGM652 is what I'm eyeing right now. Seems like the W205 looks good with classic multiple spoke or concave 5 spokes imo.. I really like the split spoke but for some reason it doesn't work for me.
Old 08-13-2020, 09:00 AM
  #661
alexasa's Avatar
c
I am running 9.5 et38. this looks bad if you're not lowered.
Old 08-14-2020, 09:46 AM
  #662
HKC43's Avatar
C43
here's my setup
Rays G025
19x8.5 et28 225/40/19
19x9.5 et44 255/35/19
lowered with H&R springs
I don't recommend this wheel setup if you are not lowered or not planing to lower your car because the front does poke a bit around 0.5inch but it looks great after lowered.
The following 2 users liked this post by HKC43:
Johnyturbo (02-19-2021), SilverC450 (04-11-2021)
Old 08-14-2020, 07:13 PM
  #663
c43PDX's Avatar
C43 AMG
Originally Posted by HKC43
here's my setup
Rays G025
I don't recommend this wheel setup if you are not lowered or plan to lower your car because the front does poke a bit around 0.5inch but it looks great after lowered.
hows the rear? I'm going 19x9.5 et40 in the rear, but I"m a bit lower than you and prob a little more neg camber.
Old 08-14-2020, 11:45 PM
  #664
HKC43's Avatar
C43
My rear is sitting fine and pretty flush. After adjusting the toe from the alignment, my rear cambers are at -2.6 and -2.5
Here are some pics I took for your reference
Old 08-15-2020, 02:30 AM
  #665
c43PDX's Avatar
C43 AMG
dude thank you so much, I think i'm a bit lower than you so getting 4mm more with that stretch should be perfect. I think I'm going to pull the trigger on the Vertini RFS1.3 flow forged in silver on my car here
Old 08-15-2020, 06:04 AM
  #666
HKC43's Avatar
C43
​​​​​​No problem man but if possible you should let the wheel guy look at the pictures and give you the best opinion.
Old 08-25-2020, 01:34 PM
  #667
mact's Avatar
2020 C43 Wagon
Hey guys, I have a 2020 wagon that I'm going to put H&R springs on (28811-4).
I have the 5-twin spoke AMG wheels I'll be keeping for my summers although I have a set of 18x8.5 +35 square BBS SR for my winters.
Will I have any issues once lowered? I was going to put 12mm/15mm spacers on, will these work for both sets or would I have huge rear poke in the winters?
Thanks!
Old 08-25-2020, 07:39 PM
  #668
Nicholi2007's Avatar
2009 C350
Originally Posted by Star4life
haha thanks. I was trying not to lower cause i dont want to rub on these michigan roads!! If KW comes out with the HAS adjustable spring for the US that is what I would get so I can lower for summer and raise for winter
I'm planning on transitioning wheels and tires to a W205 in a few years. I'm in a C350 W204.
Wheel guy says 19 x 8.5 40 offset front, 19 x 9.5 42 offset rear.
Two Questions.
1. Is staggered really worth doing? (it seems a small difference looks wise.)
2. Does the fitment seem correct? Seems thin in side wall. I had heard the front is more limited...
Old 08-25-2020, 08:29 PM
  #669
alexasa's Avatar
c
Thanks!
no.
mact (08-25-2020)
Old 09-02-2020, 09:55 AM
  #670
Diirek's Avatar
2020 C43 AMG Coupe
Looking to pick up the following off a C63:
19×8.5J ET38 and 19×9.5J ET56
Tire 245/35/19 and 265/35/19
The rolling diameters of the tires are 1.9% different - Will this cause an issue with the 4matic (I think anything under 2% should be fine)
If not, I could just pick up 235/40/19 tires for the front but I prefer not to stretch too much.
Input on the wheel and tire fitment is appreciated.
Old 09-04-2020, 12:56 AM
  #671
c43PDX's Avatar
C43 AMG
Vertini RFS1.3 custom offset/pcd order
19x9.5 et40 in the rear with 255/35/19 tires, has so much room right now.. I thought I did my research right but prob need about ~7mm to be flush..
19x8.5 et30 in the front with 225/40/19 tires, has room still to be flush.. prob 5mm.
My car is lowered with VFT H&R adjustable coils with about ~2.2 camber in the rear.
Kinda pissed that it wasn't a perfect fitment tbh. Not sure if its just my car. The tires are square shoulders Yokohama Advan V601 Max Summers.
Suspension needs to settle a bit, looks a bit high from being on jacks for a while.
Old 09-04-2020, 10:47 AM
  #672
alexasa's Avatar
c
not sure why you thought you'd be hella flush on this setup. plenty of evidence in the thread to suggest otherwise. your tire size is the main reason - definitely have to factor that in. we have people running a 255 on that same front fitment and I personally run et38 on a 265 in the rear
Old 09-04-2020, 12:09 PM
  #673
c43PDX's Avatar
C43 AMG
testing 10mm spacers rear soon and 5mm fronts. Which would be 19x9.5 et30 R and 19x8.5 et25. I have not seen setups like this even though you claim there is plenty of evidence.
Old 09-04-2020, 12:48 PM
  #674
alexasa's Avatar
c
hardly any people are lowering their cars and even less are doing a mild stretch on the tire fitment.
Old 09-26-2020, 06:19 PM
  #675
Squint's Avatar
C43 AMG 2019 estate
Alloy shopping Uk
Found a couple 19x8, 19x9 sets I like offsets between 30 and 45.
Any one had experience with these brands or specific wheels?
I don't drag or track my c43 2019 wagon just cruz to work and make pops n bangs to chear me up.
I want hastle free replacement wheels for my 19" amg oem wheels until out of warranty on a budget.
https://www.wheelbasealloys.com/allo...nch-wider-rear
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C450/C43 Wheel Fitment Guide
