Factory Tire Sizes
Factory Tire Sizes
I would be interested in hearing your thoughts:
Why is the rear tire diameter 0.3 inches smaller than the front on the c43? The rear is a 245/40Z-R18 which is 25.7 inches in diameter. The front tire is a 225/45Z-R18, which is 26" in diameter. Why would they not install a 255/40Z-R18 in the rear which is also 26" in diameter?
2017 AMG C43, AWE Touring, BMC Air Filters- 2015 BMW X3 3.5i (JB1 Equipped)
I have to agree with you I don't like the stance on my C43, I have the 19" AMG rims with 225/40Y/R19 up front and 255/35Y/R19 in back, the front tires look noticeably taller to me, maybe because of the fender flairs, but enough to make me want to put 35's all around or 40's all around to balance it.
I need to buy all season tires for the winter, as mine came with summer tires and am curious about making this swap? I did some research and AMG seems to do the staggered sidewall dia with all of the C class models?
I wonder if it would affect anything? unknowingly, I once put a shorter sidewall ratio on a '79 Trans am going from 70 to 60 and it changed the gear ratio a tiny bit- allowing the automatic trans to chirp second gear. Just my thoughts
Not sure about the improved traction answer, as I never have any spinning issue with my AWD even in the rain.
I'm glad someone else noticed this as well.
Would switching to all 35's effect the car at all? I know the smaller tire makes the gear ratio taller.
diameter should be kept within 3% of OEM size. I really doubt you are seeing a tire height difference, visually, of half a centimeter. I think you're making more of it than what it really is.
Star4life (09-22-2017)
and you'd be making it much worse, in the other direction. It's actually outside of spec it's such a drastic change.
Audi is shipping their TTRS with wider front tires than rear to reduce understeer. Less rear traction also allows the car to rotate more freely with throttle application.
