C43 slow acceleration even in Sport+ mode
Hi all, I recently got my C43 in July. I found it accelerated slow even in Sport+ mode. It took about 7 to 8 sec to reach 60mph.
Anyone has any idea what is going on my car? Configuration? Setting? Any break I need to release?
Thanks!
Thanks!
1) The engine is properly warmed up which means you have been driving it for about 10 to 15 minutes.
2) The tires are warmed up so that you don't lose any grip upon launching. Idling the car for 10 minutes before launching doesn't help.
3) You are running at least 91 octane or higher.
4) Your car is in Sport+
5) You brake torque the car to launch it as opposed to launching it from idle RPM.
6) You are ideally at sea level. It doesn't make too much of a difference in a car that utilizes turbo, but being high above sea level does decrease acceleration.
7) The road you are racing on provides you with smooth even pavement so that you have the path of least resistance to accelerating to 60mph.
If you are saying that all the above (maybe not so much #6) are true and you are still getting to 60mph in 7+ seconds, then yes...take your car to the dealership and ask them wth is going on.
Dr.b (09-27-2017)
Getting it to hit 60mph in about 4 seconds requires the following.
If you fully warm it up and punch it on any straight away you should be able to hit 60mph in under 5 sec. I can do it in less than five on my C450 on a hill climb near my house.
@op If you are looking to hit 60mph in about 4 seconds follow my complicated instructions. If you're looking to do it in under 5, punch it on the hill climb near Mr. J's house.
I have done most except No.5 break to launch. I started at fully stopped.
Are you flooring the gas pedal fully, including beyond the 'click' point? I don't know bud, it seems like something you should get a MB tech to look at. The car is pretty quick to 60 if you floor it, even in ECO. I don't think an improper break in on the engine (whether this is required is debatable) would hinder it's performance so drastically. Something is amiss.
Ng Daniel (09-19-2017)
Mine is around 18mpg (60-70 local and 30-40 freeway) Is it normal?
those fake quad exhaust tips fools lots of people.
i have a couple of coworkers asked me "is this car faster than your previous car?"
wait, it' 4.9 seconds on my c450, it is fast !
2021 Mercedes C63s AMG Coupe
Hey Daniel, I know exactly what you are talking about. And I know the problem as well. Coincidentally my car has been the same after I got it back from the Mercedes body shop after an accident. I was getting 8 seconds 0 to 100kmph. My butt dyno was telling me something was wrong, but I did not believe it until I measured the time and then confirmed it by seeing the engine data in the dynamic select menu on the command screen.
It's the voltages, you car probably has been sitting on low batteries for a while, so the car enters a limp mode where it caps the power at 262hp and torque at 300. And there would be no check engine light, so it would feel very normal until you go and check the dynamic select engine data on the command screen.
The only way to get rid of it is to have a fully charged battery and then reset all the systems using a scanner.
They are working on my car as we speak to fix this.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Thanks!
The dealership has to do it. If you have been driving the car for a few days, the battery should be fully charged. Just go and get the ECU reset. Also please go to dynamic select=> engine data and see how much power and torque you are producing on WOT.
I also checked the vehicle data section. The center HP meter showed highest HP is ard 170HP to 180HP when I press the gas all the way down.
Dealership said they don't have time today and I have to go on Saturday to check.
I hope this is a easy case.
I have just checked the dynamic select. It showed 100% (orange) when I press the gas all the way down.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Can't you read? He has a very simple problem. Nothing to do with laggy pedal. You and your AMR tune needs to sod off. Stop pushing it on everyone. Sometimes it feels like you are Matt himself using a fake account to advertise the tune to everyone.
Stronger letter to follow....
Jesus, I don't think the guy meant any harm, and as it is a forum, posts invite comments or replies and neither you nor I have the right to be personally satisfied with content.
OP said he was unable to break 60mph in under 8 sec. Assuming he's not exaggerating, you don't need a preflight checklist to determine if there is a problem.
My old V6 Escape could hit 60mph in just under 8 sec. If he can't break 7 sec in a C43 by simply mashing the go pedal something is wrong with his car.
Ng Daniel, take it in. Even if you don't have a CEL, there will be a trouble code present if the car is running as sluggish as you claim.
I have tried youtube video for resetting ECU and TCU. None was working.
Dealer said they are going to be able check my C43 on Saturday. I will update the issue.
Thanks!
Don't be so pedantic.
