Problems
2011 mercedes 300
Problems
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/02320fed_e355_4238_9cb1_d62307f57fb3_a0245d1739a1cdfebd6821dbb4851afbead976e6.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/1c8e6837_59d7_4a20_83fb_b88ce280cf71_7bc1bb5bb16023bb7a7bde711b1c8b9ef3b70f57.jpeg)
So recently I’ve had my car tuned be AMR an ever since there’s been 3 check engine lights an 3 times my cars lost all power. Can’t do anything till you come to a complete stop. And even then the car is spitting and sputtering really bad. I’ve dropped it off and the dealer has replaced a sensor and now are ordering pins for a connector. I’m still not convinced this is going to fix my issue. Is it the tune? Anyone else with amr tune have issues. It only happens when I give her the dinnah an tooling on it pretty good. Any input would be greatly appreciated attached are codes that pop up. Thanks again.
Did you contact AMR about the issue? I’m sure they’d attempt to work through it with you. You also need the codes responsible for the cel by plugging into the obd port.
Wish I could help beyond that. Good luck. Let us know how it goes in case others run into the same problem..
It's looks like you went into limp mode. Sorry to be that guy, but it could be almost anything from a bad sensor, to overheating, to your tune causing havoc.
What were the codes, though? I would imagine there was one for a sensor if the dealer replaced it. This would obviously cause limp mode.
Also, was the car throwing codes pre tune? I know the removal guide says to scan the car or if you went to them physically, they would do it. There could have been an underlying problem before you even got tuned.
Have the dealer go through everything and also make sure all the software updates are done. I know there was a fuel pump one that was mandatory because without it some people were going into limp.
Just my two cents, good luck!
I've had this exact thing happen to my Eurocharged tuned C43... took it to the dealer initially and they couldn't figure out what was wrong. They said it was throwing a torque code. Eurocharged tried to load other versions of the tune onto the car but nothing was working. They ended up taking the tune off and reverting the ECU back to stock... never happened again. I've been hesitant to tune my car ever since.
sales@eurocharged.com (11-01-2017)
How do you figure? We do not know what the codes are or have any idea what is happening. I agree with Getmercd because if the dealer is changing sensors and connectors, that must mean it threw a code for that and is a clear cause of the issue. The dealer isn't going to just change a sensor because they feel like it and think it could help. One of those codes must have been for it.
People are quick to blame the tune, but if there is a mechanical issue, the car is not going to perform.
I wasn't. I tried driving every possible way (limiting acceleration, speed, etc.) and limp mode was still being triggered every 10 minutes or so (made it a huge hassle to get the car back to Eurocharged). Not sure if it's true or not, but I noticed that the issue got progressively worse over time. The time between the first time it occurred and the subsequent time was days... and then it became hours... minutes... My car was basically non-driveable towards the end of it.
2021 Mercedes C63s AMG Coupe
Can you describe a bit more when exactly it happened? Like I know you were giving her the "dinner", but like in what gear and what speed? Also around what RPM? I doubt the dealership would be able to help with this one. Your best bet is to just let the tune settle in. Just keep driving the car in sports + and it should go away normally as the car learns your driving.
I personally do not know of any stock car having a torque limiter related code. It is all the tuned cars. I contacted a bunch of guys who were having this issue. And this is just not AMR alone. OE and EC guys previously had the same problem. It is kind of unique to certain cars, because a lot of the other guys are bullet proof with a tune. The code that is thrown is P061A or P061B, both for over torque protection. This is only triggered by a torque spike when you are around 4k rpm in 4th or 5th gear and you put the pedal to the medal. The car requests the engine for a lot of torque and sometimes that number is really high with a tune, that is what throws the car into limp. When you are stock, the car never requests so much torque, so no matter what you do, you will never trigger this code. There is a solution here for sure, but I think it has to come from the tuner, I doubt whether changing any sensors would help.
There is a guy here called heyitsfish, he had the same problem with OE and his one went away with time. So did mine. My suggestion would be to drive the car for a few days. Let the tune settle in. It should go away.
Hey guys, so recently just bought my 2017 c43. Loved, couldn't be anymore happy with it, well like everyone maybe I wanted a little more out of it. So I got in touch with the guys at AMR to have it tuned up. Very excitied about this so they strap my car to the Dyno an do base runs he's not impressed with the numbers, so we press forward with the tune, do pulls after an still wasn't impressed with numbers. He seems to think I'm not getting boost to my turbos an need to bring it back to the dealer. Giving me some suggestions. Anyone having problems with there turbos? Any other tips besides these.
1) hard reset of the ECU
2) Check intercooler piping as well as intercooler itself
3) Check electronic boost control solenoid (may be defective)
4) Vehicle did have a P0601A code stored in the ECU (resseting it did not fix the problem)
5) Check end tanks on intercooler core to ensure not leaking or separated from core
6) Check turbochargers themselves as well as wastegate actuators
Thanks for all input.
I find it interesting that you did not mention fixing ANY of the above listed items. Are you looking for a magic fix? lol
Link to your thread: https://mbworld.org/forums/c450-c43-...000-miles.html
Why don't you let the dealer fix everything on your list? Did you contact AMR? Even if its not tuning related, they are very knowledgeable when it comes to Mercedes?
I would not think any powerful piggy back will save you from this. This is the car protecting itself from a torque spike. In other words, the nannies are doing exactly what they were designed to do. Full ECU tunes are pushing a lot of power and torque, with that comes these issues. If you have any piggy back which is pushing torque outputs like this, it would trigger this code as well.
It's a tune. This platform is new. The tuners will work this **** out but I would not bet on this being a MB issue.
Tuning a car in general rips off any band-aides that are there, whether you know they are there or not.
Furthermore, there was clearly a plethora of issues pre tune from the link above, so I would not point the finger so quickly.
It is a universal fact that if the car has an underlying problem (you may not know it has one) and you amplify everything (aka a tune) then problems are now amplified with it. He could have had a faulty sensor and now that the car has more power, the sensor can't handle it, throwing it into limp. Like I said, the dealer isn't going to spend money and replace sensors ***** nilly, so that must have been an issue. This applies to any tune, not just AMR.
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Hey Guys,
That's a tune issue, and the guys at AMR can get you taken care of easily. We suffered that problem as well originally and have addressed it in our new V2 offerings.
Give them a call to get it straightened out.
AMR Performance (11-01-2017)
Former Vendor of MBWorld
18 MB E63S AMG - 17 MB C43 AMG - Much more!
Not the cause of the light. This specific vehicle came to our facility with check engine lights as well as boost issues in stock form.
So you had a bad sensor and busted pins for a connector and your blaming the tune? lol interesting....
I knew your name looked familiar! Here is a quote from your other thread. Seems your car had issues before even tuning the vehicle.
Thank you for posting this original thread link. This gave us the ability to know exactly who this person is.
Yes, we specificly gave the customer that list. Those were ALL of the issues we noticed when the vehicle was brought to our Connecticut location. As you can see from the list, he had codes already active as well historical and pending. We also noticed the vehicle was having boost issues and the factory power plot was not what we are use to seeing. The vehicle was under-powered in stock form. We spent over 4 hours discussing these issues thoroughly as well as going through the vehicle with the customer present.
Like any performance enthusiast, whether AMR Performance tuned or not, we are always willing to help out in anyway we can.
munis (11-01-2017)
This person was suppose to contact us once the got the vehicle back from the dealer, which he stated he was going to go that week of seeing us. We have not heard back from him since he left here.
- Robert
- Robert
- Robert
- Robert
My suggestion is, give the car some time to settle. With all the resets, the car is still learning. Stop giving her the "dinnah" a little bit. And just keep driving in sports+ as smoothly as possible. See if that works before you go to MB or AMR. Also for the next few days, if you are on the highway, always stick to the rightmost lane or the left lane, so you can pull over immediately. Avoid driving in the middle lane if you are in sports+.
