Brand new C43 massively losing oil! Help!
I just got a new C43 about 3-4 weeks ago, only ~500 miles on it and the "check oil level at next refueling" came up. At first I thought that it may be a problem with the sensor, so I took it to the dealer. The dealer checked it and it seems there's a leak. After pouring 2 quarts of oil, the level still seemed low and they did acknowledge a massive leak. I left the car and they're taking a deeper look at it...
Questions:
Has anybody gone through anything similar?
Should I be worried about it?
Will the engine have to be changed/cleaned..etc?
What should I expect from the dealer?
I've owned BMW, Subaru before, never any issue...It's just strange that only after a couple of weeks I find something like this.
Thanks everyone!
Yes you should absolutely be concerned and it is a significant problem since the M276 is not particularly known to burn oil as you as described.
I would ask to see if they did clean the old oil because that could be a problem but I'd also expect/assume they would clean the oil.
I don't think the oil was burned, it was leaking. I've felt no foul smell or any other warning message other than asking to check the oil level. The car is already at the dealer - I'm waiting for their feedback.
