Engine rattle on startup?
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
So, occasionally when starting my c43 I hear a rattle noise coming from the engine bay area. It doesn't do it all the time, only when its been driven for a while, then turned off for an hour or so, then started up again. Cold starts sound fine. The car only has 6k miles on it, but I don't remember this happening when it was brand new, is this normal? I plan to take it to the dealer to get looked at but given that I can't reliably reproduce the issue I'd like some advice from here as well if possible. I managed to catch it on video tonight, you can hear the rattle for a split second. Sometimes the rattle lasts longer, like 2 seconds, sometimes it doesn't happen at all.
https://youtu.be/5Wp5ev0hTeY
So the tech at the dealer listened to the video and said it was something to do with oil pressure building and that it's totally normal, but does anyone else's car make this noise?
Same thing occasionally happens to my car. I have the performance exhaust in which it would fk around with the exhaust flaps so I think it has an effect on the engine RPM. This makes my exhaust note change from high to low to high, not a smooth growl... Hopefully it isn't anything important and is just the way the car is made.
So I looked up the M276 rattle and that definitely seems to be what it is. It seems like for the non-turbo engines, there's a bulletin with a fix for it. What should I say to the dealer to get them to fix it? Or do you think I should just leave it since it seems to not be something that would cause damage over time?
Definitely don't leave it. Bring it up and say you want the sound fixed. There may be technical service bulletin for the C43, not sure as I am not a technician.
I will say this though with my own experience, when I did my first oil change (on my used car) i had the oil level set above minimum. The rattle sound appeared for me. I fixed it by filling closer to max.
Check your oil level to make sure it's at the right level. If your car is parked on an angle over night, that can sometimes cause this but with a young engine, it should not. Just like the C63 engines, you have to make sure your oil is always at the right level.
Received 2,501 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Wrong thread sorry.
