C450/C43 AMG
Dealer pressuring me for Service B
Old Dec 3, 2018 | 11:17 AM
rangehound's Avatar
2017 AMG C43
My C43 coupe is exactly 2 years old.
It has 13,000 miles on it. I don't drive it much, I'm retired.
Had Service A at 9,000 miles.
Yet because the manual states I need brake fluid swapped at 2 years or 40,000 KM, whichever comes first, my dealer is strongly suggesting Service B at around $600.00 when I JUST HAD Service A done 4,000 miles ago.
Should I proceed? Seems way to early for this.
Thanks in advance!
Old Dec 3, 2018 | 11:28 AM
noah phatt's Avatar
2019 AMG C43 Sedan
Thanks in advance!
I'm in the same position as you. Retired, don't drive much (less than 3,000 miles on my '17 CLA45) but to be safe and avoid any questions if a problem should occur, I follow the listed service schedule.
Old Dec 3, 2018 | 11:37 AM
mo11's Avatar
2017 C43
Had my service B done last week as well, 6800mi. But, I have the prepaid maintenance plan. I had the dealership do whatever was needed..
Old Dec 3, 2018 | 11:45 AM
5ilver-5urfer's Avatar
A Benz and a BMW
Thanks in advance!
Is it a leased car? If so, they can ding you at time of lease return if you didnt follow the schedule. If it's your own, then I'd probably say do as you please but I'm not sure if skipping maintenance can be used as an excuse for MB not to honor your warranty if need be.
Old Dec 3, 2018 | 11:55 AM
merlin3008's Avatar
2019 C43 AMG, 2016 BMW M235xi (gone)
I'd do it. Even if you don't reach the mileage stated, it is good practice to have the car serviced and the oil changed every year. If the car is leased, you could also get charged at turn in for not following the maintenance schedule. I almost got dinged $750 from BMW on that with my current car that I am about the turn in, but they gave me to chance to bring the car up-to-date before turn in.
Old Dec 3, 2018 | 12:34 PM
schvamf's Avatar
2023 GLC 300 SUV, 2006 BMW Z4M Roadster, 2006 Lexus RX400h
You can just do the brake fluid change for under $200 and skip the rest IMO. Prob doesn't need an oil change yet.
Old Dec 3, 2018 | 12:43 PM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
5ilver-5urfer makes a valid point regarding lease vs. owning. You're somewhat bound by their schedule if leasing. If you own, do what you feel makes sense, within reason. I don't plan on changing brake fluid until 40k miles, regardless of time (granted I daily mine so I'm at 25k miles in just under two years). I'll tackle next Summer along with rotors.
For reference, next week I'm changing the brake fluid on our Land Rover for the first time at 60k miles. Pedal still feels like the day we bought it at 12k miles, but it's never been changed. Also rolled 40k miles of extremely spirited driving on my FRS without issue before replacing.
Old Dec 3, 2018 | 03:30 PM
z28lt1's Avatar
C450, GLS 63 and a few other things
Just about every auto manufacturer and oil manufacturer recommend changing oil every year (or sooner for some), regardless of miles. The additives in the oil will break down over time (once used in a vehicle) and become less effective. Many oil analyses have shown oil still working well after a year and a half or more so it is not likely you'll have any real problems. On the other hand, I've seen 1 analysis with only very short trips where the oil was toast after a year.
The bigger issue is if you go past the year on the oil change, in the rare case of engine trouble you may not be covered under warranty. The service schedule calls for 10,000 miles or 1 year, whichever comes first. Ignoring the time factor means you are not following the manufacturers service schedule, which would allow them to not cover related items under warranty.
It's obviously an individual choice but no chance I'm going to skip the oil change after a year while still in warranty.
Old Dec 3, 2018 | 05:08 PM
Chrisk03's Avatar
GLC43, GTI, X3, Mazda3
Thanks in advance!
Not sure of your location and going to assume you OWN the vehicle, but if it were me, I'd find a good/reputable Independent mechanic in your area to do the brake service. Hell, even bring the MB brake fluid, if you have to, but I'm betting it will come in much less than $600 for Service B. Do a quick search online to see if there is an Indy mechanic in your area.
You could also see what the dealer would charge JUST to do the brake service...and do your oil change, elsewhere, depending on the pricing. Good luck!
Old Dec 4, 2018 | 03:07 AM
guhvies's Avatar
2017 C43 AMG Saloon
But if you do go to the dealer for the B service, make sure you ask for the navigation maps to be updated. And don't be put off by the dealer.
Old Dec 4, 2018 | 09:52 AM
Also a good option. I'm a big supporter of DIY oil changes. Only the most basic technical knowledge is required to change the oil. If you can read and understand righty-tighty, lefty-loosey, you can change the oil on this car. Not comfortable with brake fluid, totally cool, but investigate with the dealer or an independent shop and keep the service receipt and you're all good.
Old Dec 4, 2018 | 10:42 AM
Chrisk03's Avatar
Sorry for off topic, OP, but RC do you drain or extract for your DIY oil changes? German car oil changes are pretty darn easy compared to others because of the filter on top...and would be that much easier with extraction. Just trying to decide if I should get an extractor or continue sliding under the vehicle to drain. Would save me about $150 on a Service A at my dealer to DIY, which I will def do out of warranty.
Old Dec 4, 2018 | 11:48 AM
I have a set of race ramps, a creeper, and always install Fumoto drain valves on my cars. It's really easy for me to just drain because I've invested in tools over time. However, I'm seriously considering going the extraction route in the near future though. Many on the board here use and swear by the extractors. Nothing wrong with it from my perspective, just a matter of what you might already have tool-wise. The only tick against extraction is remaining potential debris. You're never going to know (or remove) if there's ever any metal shavings or particles lurking in your oil pan if you're exclusively extracting.
