Miles to empty
after the initial warning, after you press ok, it will continue to show miles. but when it reached the last gallon, like at 25 miles, it will stop showing miles left even after pressing ok.
W= WALK!.
I would not trust accuracy as it is guessing at fuel in tank since sloshing around and actual amount...
then it car has no idea how you will drive in couple of miles.
And we do not want to get air in fuel lines cause then a PIA to start since you hve to get fuel baco u pto injector fuel rail under pressure which is hard to do with air in line
Im like you, or rather have learnt on here that yes running low can and will damage the fuel pump.
on the gas cap, it said use 91 gas.
will it harm the engine if i put 87 gas?
i kinda feel guilty about it, so i filled it with 91.
Reason being, turbo engines use premium.
Running your vehicles low on fuel is dumb for other reasons besides mechanical. Think about natural and man made disasters, or other events that may disrupt the fuel supply chain.
