New Cold Air Intake From MST Performance
#101
You'll have to clear that code, it won't clear itself. You can get it to clear (but it will remain stored as a fault) by disconnecting the negative battery terminal for about 2 min, and then reconnecting it. I don't know if SCN is required to read and fully clear these out of memory on MBs but if so, find an independent dealer that will do it for you. If you don't, the dealer will see that fault stored as soon as they plug into the car.
#102
I did the ECU reset, left battery unplugged for about 20min. Put everything back together and so far no cel/code!
Thanks everyone for the help in clearing this issue. Great community! Saved me a few hundred bucks by not going to a shop!
Im going to let the car learn to work with the intakes and report back!
#103
I am going to continue to hold off mine. I would really like for MST to address the issue for us who have purchsed. Does anyone have a direct email?
#104
2018 C43 AMG Brilliant Blue Metallic
This is there response: I dont think they understood the sensor issue
Thanks for the reply. We checked the forum and integrated the issues as the following pointsThe reasons for the P1191 Check Engines Light (CEL) Code - 1) O2 sensor been connected/disconnected. 2) Nowaday Mercedes Benz have the most sensitive protection system and it would turn into safe mode once plugs being remove or disconnected. A fault code remove action is needed and the ECU will adjust the air fuel ratio after decode. Most factory engine tuned with rich air fuel ratio. Our induction system give more airflow and oxygen to the engine, which means satisfy the combustion need to optimize condidtion(combustion efficiency). Exhaust pop sound would reduce but still able to notice. (Pop sound cause from rich airfuel ratio). On the other hand, turbo spooling sound and induction sound becomes another new symphony in your cockpit. After we back from Taipei AMPA show, we will add notes to our website as well as the C43 intake installation instruction. If you have any other questions, please do not hesitate to contact us.Thanks again for keep us posted. Hope you enjoy your our product and new performance on your car!
#105
I know I can read the codes with my JB4, but does anyone know where to find a comprehensive list of codes and definitions? I have looked online, but come up short for w205 series.
#106
Alex
#108
Did the intake come with extensions for the sensors to the air filters? Could they be backwards (wires swapped) or installed the wrong way? Some of those clips can be forced in the wrong way, though i havnt looked at that specific clip.
#113
I'm tuned, I don't think I would have messed up the extensions. I don't see how you can force them in the wrong way. At this point I'm lost and just want my car to be back to normal, lol. Its a shame few days before the intakes I was out racing with my buddies 2012 C63 P31 rated at 481HP and keeping up and taking him from the line. Now I'm in LIMP mode and he wants to run again!!
Alex
Alex
#114
This is insane. There is no way that MST should be "taking note" of the issue. Is anyone else experiencing the same? I am keeping mine boxed up in anticipation of sending it back. I emailed them the link to this thread.
#115
I am tuned but no CEL from the MST intake.
I would also recommend let the ECU go to sleep before installation to prevent a CEL.
The following 2 users liked this post by xX G Xx:
CA400 (04-25-2019),
eazy_duz_it (04-25-2019)
#116
Alex
Alex
CA400 (04-25-2019)
#117
Response from MST......"Hi Marcus, Thanks for your feedback, we understand your concerns as well as other customers who ordered the C43 intake.Now we need to collect all information to figure out the problems and find a solution as soon as possible. Also we will contact every customer who bought this intake once we back to the office on the next coming Monday. Sorry for the wait. We spoke to a local Mercedes Benz engineer, which regarding the CEL issue. We wonder is your car C43, C400 or C450? This might be the reason why the check engine light would be on. Please let us know. Many thanks! "
#118
I got a c450
i mean I’ll throw in my 2 cents on it— but I really just think they used a grommet that wasn’t air tight.
not to mention the right side was much tougher to fit then the passenger side.
Overall— meh— butt Dyno don’t feel it— but the drive feels smoother (that first to second). But still getting over the loss of my exhaust “misfire”. But take in consideration— a tune might make this intake more efficient.
#119
After sealing the grommet the car felt much better! I can hear the turbos now but you have to listen for it! I truly can’t give feed back until I drive the car with out the P1191 Cel.
I hope MST really works on this issue!
Alex
#120
I haven't installed mine, yet. I do think they should "fix" whatever it is at no cost to the customer. BMS has done this with their design flaw, AFAIK.
#121
I got a c450
As for the exhaust, drive it for a few days. Let the ECU relearn. Even lock the car at night. The exhaust sounds should be back. Mine are unchanged. There was another guy on FB that complained of losing the pop/bang. We been msg'ing and he said its back.
#122
eazy_duz_it (04-29-2019)
#124
From MST.....
Hi Marcus,
Sorry for replying late. We are all back to the office today and started getting in touch with all C43 intake buyers. We have talked with some customers earlier, and we think the CEL issues that people discussed a lot mainly occurred to C400, C450. From the feedback we received, C43 car users didn't have this problem. So you could unpack and install it, and please make sure follow the instructions below: 1. Switch the ignition off2. Open the hood and trunk, check the location of the car's main battery, disconnect it and left for about 15 minutes to let your car completely turn off. (This way ECU will clear the using history, so it wouldn't trigger CEL with a code P1191)3. You may start installing with our installation instruction. On the other hand, we will be doing a thorough test for each car model to find out the core problem of how the CEL happened. We are now integrating issues so that we are able to know what we can do for you.
Hi Marcus,
