C450/C43 AMG
C43 Turbo Leak
Old Apr 14, 2019 | 10:22 PM
matt pun's Avatar
C43 AMG
C43 Turbo Leak
Hi guys. I read a lot of threads from here or fb reporting the issues on turbo leak. This is apparently a common problem. The first sign of this happening is losing horse power, feeling the car being less powerful than used to be. The second phenomenon is the boost reading in turbo gauge. No full boost appears (usually 1/3) and boost is not holding. I notice there are only intermittent readings in my turbo gauge even I floored it. So, is there any turbo leak, before I tell the dealer to fix it?
Old Apr 14, 2019 | 10:25 PM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
Could also be a bent turbo fin as well.
Old Apr 15, 2019 | 08:56 AM
NYCSoiL's Avatar
2018 GT R; G82; M340
Just take it to the dealer. Mine had rust on the exhaust flaps connector and this was the reason for the reduced power
Old Apr 15, 2019 | 09:49 AM
munis's Avatar
2021 Mercedes C63s AMG Coupe
There is a thread on boost leak. It happens from the top of the intercooler. The pipe is usually loose. If you search for it you will find it.
Old Apr 16, 2019 | 12:53 PM
HTXgearhead's Avatar
2018 C43 sedan
What Munis said is probably the issue.
I had the intercooler to manifold hose fail 3 times before the dealer ended up replacing it for me. Check that connection first.
Old Apr 17, 2019 | 03:37 AM
waisoserious's Avatar
GLC43, X P100D, S P100D, CT200H
I think a bent impeller/rotor fin would cause massive vibrations. You could probably hear it.
Old Apr 17, 2019 | 04:50 AM
matt pun's Avatar
C43 AMG
Luckily I don't sense any abnormal vibration in the engine. Just notice the boost is not holding even in full throttle.
Old Apr 17, 2019 | 08:05 AM
rustybear3's Avatar
Not necessarily so. I had a bent fin on my Cadillac ATS turbo, and displayed no vibration at all; just lack of power and acceleration.
Old Mar 20, 2020 | 06:43 AM
Marcus Duffner's Avatar
ML55 AMG, CL65 AMG, G63 AMG
Same on my M275 TT. Heard some hissing when RPM was reaching 2500 and above. Looked around for some leaks but couldn't find any. Ordered the T-bolt clamps and while installing those Y connectors from IC to plenum separated completely. Changed all, Y -pice plus all three clamps plus the 4 T-bolt clamps for the pipe connectors. Will do a test run with SD soon to see the pressure readings.
Old Jun 29, 2020 | 02:27 PM
saadzafar's Avatar
C43 AMG
It happened to me too! Idk what to do besides take it to the dealer for the look, I also noticed the usual "whistle" you get from the turbos when you accelerate doesn't happen to my car anymore.. this really sucks
Old Jun 30, 2020 | 04:47 PM
AhEmGee's Avatar
2004 E55 K Wagon &. '96 SL500
you would not feel a vibration from something as small and light as a bent turbine or compressor wheel. They weigh a few hundred grams. You would probably hear it though.
