C450/C43 AMG
Sudden lack of noise when downshifting C43 AMG
Old Jan 22, 2020 | 05:29 PM
Brad1511's Avatar
C43 AMG
Bought at ‘18 Mercedes C43 last week with 3700 miles on clock. It’s been amazing fun all week, I’ve loved it. Usually when it’s in sport + and I brake, it down shifts through the gears and makes a lovely revving growling noise and crackle at each gear it drops. A real head turner coming up to traffic lights etc. However today I drove economically over a long distance as it was 50mph average speed the whole way. Now, for some unknown reason, when I’ve put it back into sport + and braking, there’s no sound whatsoever. It downshifts as it should but just does so extremely quietly with no fuss like it’s in comfort mode. No over revving and no lovely loud growl and crackles at each gear drop. I’m devastated.
Honestly it’s taken away so much of what I love about this car. Can someone please shed some light on why this has happened and help me resolve?
TIA
Old Jan 22, 2020 | 06:15 PM
mo11's Avatar
2017 C43
Try flooring it a few times upto 3rd gear in sport+ and let go, off the gas pedal quickly and floor it again. Do a few of those in succession.
It’s probably still “learning” mode since you’ve only had it a week, and stuck in learning your eco driving mode.
Old Jan 23, 2020 | 02:25 AM
stockbmw's Avatar
2018 C43
On my 18 with PE, you get 2 noises in all modes. 1st is the crackle and pops specially more so in S+. When coming to a stop, it would downshift some times crackle and popping but not all the time. 2nd is regular loud exhaust notes, S+ is louder.
Do a transmission reset and leave it on S+ for next few days and drive like you stole it, if you feel your car is shifting too eco.
Old Jan 23, 2020 | 04:01 AM
Brad1511's Avatar
C43 AMG
thanks for the input. I will certainly give this a try today. Never driving economically again!
Thanks for the advice, excuse me for the lack of know how but how do I do a transmission reset?
Old Jan 23, 2020 | 08:11 AM
W205C43PFL's Avatar
http://www.mercedesmedic.com/reset-m...-instructions/
Try this should work
Old Jan 23, 2020 | 09:01 AM
MatthewJ's Avatar
'15 C400 and '15 ML350
The car makes the pops by spraying extra fuel at those points. If you drive it differently, change the battery, tune it, change to E40, have drastic weather change, etc. Basically anything that messes with the long term fuel trims, the car will not have the same pops until it learns and adjusts back to where it can safely overrun the fuel for pops.
As others have said, you can try driving in S+ more or just give it a day or so. I wouldnt reset the trans unless its not shifting correct, the TCU learning doesnt control the pops only clutch pressure and valve fill times.
Old Jan 23, 2020 | 09:05 AM
hlieberg's Avatar
2018 AMG C43 T
This has happened to me as well, but it was just temporary and the nice sound was soon back again. At that time I think I mostly drove it in S+ all the time.
Old Jan 23, 2020 | 10:50 AM
Brad1511's Avatar
C43 AMG
Thanks for the feedback. However it doesn’t seem to be just be the pops and crackles gone, it’s the actual shifting of the gears. It’s not downshifting until much lower revs hence the reduced noise. Where as before it was downshifting nice an early with a loud rev and crackle. Now it seems to be downshifting at around 1500 rpm when braking where as before it would downshift at about 3000 rpm. Which is causing the reduced noise. It also seems to not hold onto gears as long where as before it would stay in gears for as long as possible without upshifting. Not unless I fill have the accelerator pressed down, it up shifts at low RPMs. I’ve driven it manually and downshifted At 3000 revs and it makes the lovely roar and crackle like it previously did it automatic. I don’t want to constantly drive around in manual so would you suggest resetting the TCU?
Old Jan 23, 2020 | 10:59 AM
MatthewJ's Avatar
Trans learning reset is fairly easy to do, but with only 3,700 miles it probably doesnt have enough data/adjustments to notice a difference. It happens very slowly.
I would drive like normal for a few days (in S or S+ , whatever you typically use) and if it doesnt improve then try the reset.
Also FWIW on the next road trip, activating cruse control in sport should change the behavior so the car selects the highest gear for fuel econ. The peddle sensitivity will still be there vs the "numb" effect of E mode. Should achieve the same mpg on the trip. It would then take either aggressive driving or a switch from S to C, back to S for the car to go back to holding gears.
Assuming the programming on the 2018 is the same as 2015.
Old Jan 23, 2020 | 12:01 PM
Brad1511's Avatar
C43 AMG
Thanks for all the help. Really appreciate it. Taken it for a long drive today where I very much pushed it to its limits in sport +. Seems to be a little better but only making noise when downshifting some of the time. Will keep at it over the next few days and update. Seen a lot of similar threads that nobody can seem to find a definitive cause led to people going to MB and being advised to have a software update on the coupe’s transmission bit that has made their cars quieter than ever!
Old Jan 23, 2020 | 03:59 PM
carlislep's Avatar
C450 AMG
Hey guys, I got my 2019 c43 tuned end of Dec by Eurocharged. However, since then i have been driving very economically, as I had a few long haul family drives, and we have had bad weather (snow). Im worried my car as "learned" this.
Would I benefit at all from doing this retset? Does the method work on 2019 9 speed trans? I read somewhere i can unhook the neg terminal on battery and it resets trans as well.
Suggestions?
