BMS Intakes
I had no issue with my V2 touching the hood when I had it. Perhaps it was an installation issue. You have to adjust both the angle of filter and the angle of the pipe.
I'm not surprised a tune competitor would say our intakes are bad, lol.
I'm no rocket scientist, but it seems pretty obvious the BMS set up is flawed from the jump. Removing the stock pipes that actually funnel air to the filter seems stupid, also the part of the filter that faces "into the wind" is a big slab o' plastic. Tie that together with the airflow restriction from closing the hood, your only getting air to a small percentage of the filter, and that's basically by accident. The air eventually makes its way to the filter, rather than being sent their directly. (and intentionally)
I also closely monitored the IAT on my JB4 with both and didn't notice a difference at all.
Most people get the MST because they don't want to cut that plastic engine cover so they convince themselves the MST is better. I don't think it is.
