Transmission Behavior and Exhaust Note Changed After 40K B Service
Thank you for reading this post.
Recently I brought my 2017 C43 coupe for a 40K B service at a MB dealer. After I got my car back, I noticed that the transmission behaves differently. In Sport+ mode, it becomes more jerky. In Eco mode, it would glide a shorter period than before and would exit the glide mode with a more noticeable jerk. Also the gear shift becomes more unpredictable. The gear box was not the smoothest at the beginning but it understood my intention pretty well in all modes. Now everything changed, especially in Sport and Sport+ mode. At cruising speed, sometimes a tiny bit of gas would make the gear box downshift but other times, even at the same speed and same gear, more throttle wouldn't make it downshift. It's like you and your old friend don't recognize each other suddenly, which is so frustrating.
There are some changes to the exhaust note. For example, previously when I'm in Sport+ mode at 3rd or 4th gear, if the rpm is about 3k and I lift the throttle, the car will make some burble. It was pretty predictable. After the maintenance it wouldn't do that or only make some very short burble. The change in the exhaust note pattern is pretty noticeable. I'm a little bit frustrated after the maintenance and will schedule a revisit to the dealer.
The only change I like is, when start up the car in Sport+ mode, the engine will rev to 2K+ rpm and give some crackle and pops, which it didn't do before. I've attached a video showing the start up.
With all these changes, I'm a little bit worried that some might be something wrong during the maintenance. Do you have any idea what might have been done to the car in the maintenance to cause these changes? I would really appreciate your input! Thanks.
As for the s+ startup, my car does same burbles but haven't given any attention on the rpm it goes up to.
I would reset the transmission again and drive like granny on comfort for few hours. Unless you want your car to shift at higher rpm, pop it on s+ from reset.
There are some mistakes on it. First my car is a coupe, should be C43C4 not C43A4. The tire pressure is wrong as well. They were inflated to 44 in the front, 38 in the rear. Have to manually deflate the tire a little bit. According to the paper, they adjust the tire pressure based on the specs of r18 wheels while mines are r19 . These mistakes also made me not very confident in the dealer that they actually did right to the transmission.
