2020 C43 AMG powertrain/ride issues
So I bought a brand new 2020 C43 back in June, already have 9800mi on the car but from day one I ran into issues out of the norm or it might just be me being OCD. At Hwy speeds there’s a vibration in the steering wheel that you can also feel in the pedal. You start to feel it around 67-78mph, once I hit 80-90mph it almost goes away but after I climb past 90mph it gets worse the faster I go and you really start to feel it. Issue #2 car wants to have power when it feels like it. Trying to catch up to a Kia Rio feels like a mission. Car has only hit 384hp once and likes to sit around 320-370ish range on the gauges. Issue #3 the gear shifts feel way to harsh. From getting off the line to coming to a complete stop doesn’t matter what mode you’re in even tried controlling it in manual mode still feels like a tranny from GM’s pick up line. Took it to the dealer told me they can’t test it at Hwy speeds because the interstate is too far away but they’ll do their “best”. Got the car back the next day service advisor told me the tech didn’t find any problems only thing he noted that it looks like my front left tire is taking wear from cornering. So he balanced the tire for me to help try and lessen the vibration. The power side he told me the car is performing how it should be there’s nothing wrong. The drive home it still vibrates and performs the way stated above. I have a 2008 CLK550 cabriolet and honestly I feel like that tank feels Faster/more like a AMG than my C class. This is my 9th Benz and honestly I’m just ready to put it away.
that’s a wrap on all my problems (: thanks for hearing out my b******* for not going with a C63 S let me know if y’all are having the same issues or not.
Was present on the 2018 I had (which was a lemon). Present on my ‘20 as well. It must be a trait baked into the DNA of the C43.
I also am down on power. Car is only making 267 horsepower (max), and I had to thrash it within an inch of its life to achieve that.
The C43 is mostly well-reviewed from a performance perspective, and I thought my first car’s issues were atypical because it was such a mess.
After having my second C43, it just seems not very well-sorted. The more you spend time with it, the more it gets exposed. I almost went back to a C63 before getting my ‘20, but I wanted the AWD.
Had to have all the rotors replaced within the first month of ownership due to corrosion, permanently baked on rust that I couldn't eliminate off the rotor faces no matter how many miles I put on the car, and a vibration through the brake pedal. Also had to have the rear differential replaced 3 times. Among other things lol!
My '20 C43, on the other hand, was rock solid for the first few months. All the doors shut with a nice "thud," all the buttons and switches feel very positive/crisp, the leather on the interior is immaculate, paint has a beautiful finish, and the panels fit very nicely.
Then, the battery started to crap the bed, and I started to lose power (have a thread on it). Taking the car to the dealer on Thursday.
The transmission harshness really is normal. It's just a side effect of the wet-clutch design. Some shifts will be smooth, others will bang through the gear change, especially the first three in this car.
The issue with power delivery could be due to any number of things. I see your profile says you're in Florida. High ambient temps and high humidity are going to lead to reduced power. Your car may be more sensitive to it than other vehicles, and there might even be changes for the 2020s in the factory mapping that are pulling power more than previous years when the ambient temp is higher.
As far as power goes, why don't you take it to a dyno and get a clear answer instead of going with the ondash system? I don't trust that boost gauge and the hp/tq thing.
Of course I went out for a drive with the foreman yesterday and it didn't act up in over 30 minutes, so i'm not thinking they are going to replace it a second time just yet.
If you have a rhythmic vibration that you can feel, especially up through the seats, it's like the driveshaft. This is apparently a very common issue on the C-class (C300 -> C63). Most dealers should know what you are talking about if you bring it up to them. Mine shouted "Driveshaft" when just explaining the problem over the phone the first time!
hey there which dealership did you get your car serviced? I have a 19 and yes I feel these rhythmic vibrations
See if the original poster in that thread provides answers that may be helpful
https://mbworld.org/forums/c450-c43-...ise-issue.html
Recap of the problems
1. The late and sluggish automatic shift from first to second gear, which jerks me forward in my seat. This behavior is not repeatable — sometimes the shift is crisp and smooth.
2. The vehicle intermittently failing to respond to my manual upshift request from first gear to second gear when I’ve got the accelerator pedal pushed pretty far down to the floor.
Findings from today
- The late/sluggish upshifts still happen, but they are not as jarring as they were the last time I experienced them. Perhaps the shifts are improving as I accumulate more miles on the car.
- The shifts are generally crisper when I have the Dynamic option (rather than, say, Sport) selected for the Drive parameter in my Individual configuration.
- The vehicle still fails to respond to my upshift requests sometimes, and this issue is not limited to the shift from 1st to 2nd gear. In this video (had some upload issues, so it's a video of a video!
), you can see that the vehicle does not respond to my first click of the upshift paddle in 3rd gear. Only one I click it a second time does the vehicle upshift to 4th.
Findings from today
), you can see that the vehicle does not respond to my first click of the upshift paddle in 3rd gear. Only one I click it a second time does the vehicle upshift to 4th.My car has the analogue cluster and the shift light will flash red when I try to prematurely "short shift" into higher gears.
The car is never fully manual; the ECU employs restrictions on both upshifts and downshifts and will save you from over-revs with a soft throttle-cut when you hit redline. More like an artificial manual you might say.
Interested to know your results after switching to ESP Sport and ESP off settings.
Findings from today
