Who follows the 10k mile oil change?
I've always changed mine every 5k, Motul/liquidMoly/Redline and changed out the diff oil, been pretty lucky with my euro cars so far.
Which brands do you guys like here?
Oh wait I actually have everything covered *** me 🤦♀️😑😭🥺
It’s no mess no fuss. Takes about 30 mins total.
Decently as well personally not a huge fan of liqui moly What a trash oil
These cars run hot, and I would say in my amateur mind that oil degrades quicker.
I've always used Motul/Liquimoly and never had an issue. I am curious with the ester based oils? Can you elaborate?
other then that you should be good and make sure your getting your oil flushed every other oil change well atleast I do and my car still sounds the same as it did the first day I got it
but if you want max performance vs longer intervals then I’d say go w motul since ester based oils need to be changed more often believe me I researched the **** outta oils as I own a rdx, srt hellcat widebody, c43 and a trackhawk 😂Last edited by 19’43s; Sep 11, 2020 at 01:06 AM.
5000 km is what I was thinking for a tuned car with aggressive driving as well. Next week I may install downpipes for stage 2. Wasn't sure whether to do it or not because it will change the exhaust note but worst comes to worst I'd have to fix it later with an aftermarket exhaust. Fingers crossed for some decent gains.
oh and let us know some numbers once your mods are finished.
