C450/C43 AMG
Latest mod on my 21 C43
Old Mar 9, 2021 | 02:21 PM
ctsvette's Avatar
C8 Z06, Mercedes C43 sedan, Jeep Grand Cherokee
I finally got around to installing my 19" wheels. I think they look awesome but there's definitely a ride penalty over the stock 18" wheels. The ride isn't much stiffer (I have Michelin PS4 tires on the 19"s) but there's more road noise that transmits into the car. I started blacking out the handles although they're tough to do right. I still have to black out the chrome strip on the end. Next up would be the panamericana grille.
Old Mar 9, 2021 | 04:41 PM
mo11's Avatar
2017 C43
Congratulations on the new wheels! I too had 18” OEM wheels, changed to 20’s and now 19’s. Both rode better than the stock 18’s on rft. What tire pressures are you using? I used to put 38psi f, 36psi r. Those pressures were fine, but 34psi f and 32psi r that I have on my 19’s now ride and perform even better. I also hit a huge pothole on these new pressures and my rims and tires are fine.
Old Mar 9, 2021 | 04:47 PM
tweaked9107's Avatar
2021 C43 Wagon
Very nice!
Might be a stupid question but what are you guys doing without run flats? Have you bought a spare and squeezed it in the back or just taking the risk?
Old Mar 9, 2021 | 06:58 PM
ctsvette's Avatar
I have an air pump and flat fix kit. I've fixed several flats easily in the past. The only time I'd be screwed is if the tire ruptured.
I was running 39 in the front and 34 I'm the rear, that's what the car plate recommended. Maybe I'll try lowering the pressure.
Old Mar 9, 2021 | 07:17 PM
zibby43's Avatar
'20 GLC300 SUV
I'm a sucker for Briliant Blue.
Old Mar 9, 2021 | 08:51 PM
C43HeartBoost's Avatar
C43
Originally Posted by tweaked9107
Very nice!
AAA membership.
Plus, I had a flat on my “run-flats” and it was almost instantly a “flat-flat.” I think reliance upon a run-flat tire is false security.
Old Mar 9, 2021 | 08:54 PM
W205C43PFL's Avatar
Understandable because that blue is brilliant indeed!
Old Mar 9, 2021 | 08:55 PM
C43
Looks great man!
Old Mar 9, 2021 | 08:59 PM
W205C43PFL's Avatar
Originally Posted by C43HeartBoost
AAA membership.
Yes on top of that, from my experience, the stiffer sidewalls has a tendency of bending wheels when it comes in contact with a pothole. Not a fan of the ride quality of the run-flats either. I would even say that there is an increased risk of having flats with run-flats compared to conventional tires, I had run-flats that bulged (just my opinion and experience anyways)
Old Mar 10, 2021 | 04:22 AM
2021 C43 Wagon
Fair enough. I'm due to pick up a 2021 C43 Wagon next week and from previous experience hate run flats. My plan is to see if I can squeeze a spare in the back underneath the boot/"trunk" floor.
Old Mar 13, 2021 | 06:41 PM
ctsvette's Avatar
So I'm good with the ride of the 19 inch wheels but I have to say these tires PS4 are making a ton of road noise. We just did a 1.5 hour highway trip and it was ridiculously loud in the car. It was quiet with my 18 inch run flats. I have ps4s tires on my Corvette and they are quiet so I'm not really sure what the issue is. Keep in mind these tires/wheels were on another car before I bought them. I'm wondering if they have some strange wear pattern although they look fine. Thoughts? I thought maybe lowering pressure would help but I'm reading lower pressure will just make them louder.
Old Apr 1, 2021 | 12:30 PM
Senid Avdic's Avatar
Mercedes AMG C43 Sedan
Looks great. What are the wheel and tire specs you're running?
Old Apr 1, 2021 | 01:55 PM
ctsvette's Avatar
They're standard size 19" wheels with PS4 tires. They were from an earlier year C43 and he powder coated them when I bought them.
Old Apr 10, 2021 | 11:36 AM
jevsays's Avatar
2016 C450 AMG, 2005 C230 Kompressor
Looks good! Had mine powder coated satin black.
Old May 19, 2021 | 04:08 AM
aaronBLUEeyes's Avatar
‘17 C43 AMG, ‘10 C300 4MATIC Sport (previous)
I’m debating powder coating my factory wheels or buying after market.
My 17 c43 has these wheels:
I don’t like the machine lip or the spoke faces machined either.
I also wish they had a concave design, but think they might look better powder coated.
What do you guys think?
Old May 19, 2021 | 06:24 AM
djprov431's Avatar
2021 C63S Coupe
Just so I'm not mistaken, can someone confirm that the 19" factory upgraded wheels which I have on my 2021 C43 are indeed run flat? I assumed they are and I don't have a flat repair or compressor kit in the trunk like the C63s has. I'll have to take a closer look at the tire -- does it actually say run flat on the darn thing?
Old May 19, 2021 | 10:11 AM
jhpmbusa's Avatar
2021 M550i
will say MOE. If it is straight from the factory will be run flat for sure.
Old May 19, 2021 | 10:20 AM
ctsvette's Avatar
Go for it. I agree, I think all black wheels looks better. Plus it's harder to tell if they're dirty unless you go gloss black.
Old May 20, 2021 | 01:25 AM
I’ve been designing mock-ups in Photoshop of different wheels treatments. Considering gloss white with red stripe & amg wordmark, copper and satin black with red stripe and amg wordmark.
Luckily I’m a graphic designer lol!
Powder Coating mock-ups for my c43 AMG wheels: gloss white, copper, gloss black.
Old May 20, 2021 | 07:18 AM
ctsvette's Avatar
I'd go with the black. Not a fan of the white and I think you'd get tired of the court pretty quickly. Try it a graphite color, that may be better than black.
Old May 21, 2021 | 12:06 AM
C43 Designo White and Black Napa Leather interior.
@ctsvette I’m leaning towards the white actually, without the red stripe. Was at shop today that would do the work and they liked both copper and white.
I have black and white Designo interior with red seat belts, so that’s why I’m leaning that way — to match interior.
3-up C43 AMG wheel powder coating concepts: Gloss White w/ Red Stripe, Gloss White and Copper.
Old May 21, 2021 | 12:25 AM
stockbmw's Avatar
2018 C43
They are continental SSR - self supporting runflat
