C450/C43 AMG
Owner review 2021 C43 & C63
Old 05-31-2021, 07:22 PM
W205C43PFL's Avatar
Received 2,654 Likes on 2,257 Posts
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Speaking of IWC clock in the C-Class 205, I heard that non-AMG ones that have the Mercedes branded one is also called IWC something with a different part number sans the IWC lettering that the C63s one has. I need to find the source though, I will update this post when I find the source.
Edit 1: I couldn't find the source that I was looking for (that had supporting details such as them disassembling the two clocks to compare the circuit board, revision number, manufacturing processes/parts sourced, etc.). As far as I remember, they noticed the only difference between the two clocks were really the styling on the front where customers actually see such as the IWC branding, the red accent, plus the different design of the clock hands. The back of the clock when removed from the centre console says AMG on the IWC one while the regular one just says Mercedes. They are both made in Tunisa. However, there were clearly no IWC movement or any clock movement whatsoever, it is just a digital chip with clock hands controlled by a SAM module.
I did a quick search and the part number 213-827-13-00 is the IWC branded one while part number 213-827-20-00 is the regular Mercedes one. I am sorry that I wasn't' able to find the original source.
Last edited by W205C43PFL; 06-01-2021 at 11:05 AM. Reason: Added information on the source
The following 2 users liked this post by W205C43PFL:
djprov431 (06-01-2021), zibby43 (05-31-2021)
Old 05-31-2021, 07:25 PM
W205C43PFL's Avatar
Originally Posted by jhpmbusa
TWO THUMBS UP on the review!!! hopefully all those people who say "43/53 are not real AMGS" actually read this and realize how great of a job MB did by bringing in the mid-tier. It really helps people who would have never experienced an AMG at all actually get a chance to consider/experience the magic lol.
There are plenty of us that can't rely on a rwd vehicle or commute day to day on v8 mpg ratings. They honestly perfected the Jekyll and Hyde for those who need it the most!!!
Couldn't agree enough on the RWD vs 4MATIC part especially for those who live in Canada or colder states of USA.
Old 06-01-2021, 01:56 AM
superswiss's Avatar
Received 3,937 Likes on 2,629 Posts
2019 C63CS
Originally Posted by djprov431
I also made two other observations - The 43 shift light (at least in S+) is progressive - the bottom of the screen lights up red when you're close to the needing a shift, and then the entire screen flashes red at the max shift point -- one second later and the ECU cuts it.....On the 63 (and maybe I just missed it, but I doubt it) it's not progressive with the shift light, just the bottom lights up red, no entire screen flash....I will need another look to confirm.
Shift lights work the same in the 63. Builds up red from the bottom in segments and then flashes when it's time to shift. You must have short shifted it. I do hope you are past your break-in period before doing this, though.
Old 06-01-2021, 07:48 AM
djprov431's Avatar
2021 C63S Coupe
The 43 has a little over 1000 miles on it, the 63s has 2800 --- both cars got the widely varied RPM and non-babied break ins -- they're golden
I do have to double check the 63 shift light function - I've manually shifted the car so many times to red line that I'm sure I would've noticed if they were indeed the same between both cars - but mistakes happen!
Old 06-01-2021, 07:56 AM
djprov431's Avatar
2021 C63S Coupe
Thanks for the comment! I couldn't agree more -- the 43 is well worth the badge - with the added perk of AWD and better mileage - you nailed it.
Old 06-01-2021, 07:58 AM
djprov431's Avatar
2021 C63S Coupe
Originally Posted by zibby43
Thank you for sharing the driving impressions! Really useful to have direct comparisons between the C63 and C43 from someone that actually *owns* both cars.
Hell of a garage. And that IWC clock on the 63 is hands-down one of my favorite touches in the 63 cabin. Little details like that make the C63 so special.
Thank you! I'm really enjoying sharing my experiences on both cars, and being part of the forum again - I took way too many years off from MB! (I agree on the clock!)
Old 06-01-2021, 09:35 AM
  #32
superswiss's Avatar
2019 C63CS
Would seem an odd malfunction if it didn't in yours, but I guess I've seen weirder things. I drive 90+% in manual mode and have 21k miles on mine, so it definitely flashes. There's even a last ditch shift advise I've seen come up on the left (I use the SuperSport layout) showing the next gear and an arrow pointing up. It doesn't always come up, so I haven't quite figured out what triggers it. I have a feeling it's just before it hits the rev limiter, or when it actually hits it. I'm sometimes not fast enough with the shift especially in first gear, so I occasionally run into the rev limiter.
Old 06-01-2021, 09:42 AM
  #33
hyperion667's Avatar
Received 3,412 Likes on 2,854 Posts
2012 CLS63
The difference in start up sounds is funny.......the 63 totally wins that everyday!
Old 06-01-2021, 11:01 AM
  #34
djprov431's Avatar
2021 C63S Coupe
I have seen the gear up with number indication on the left of the AMG screen while in manual, in fact you can catch it in one of the videos above. I still feel quite strongly that the 43 and 63 shift indications are different - will need to confirm via video here soon....here are some screen shots from #2 drive video above -- I still think it's different than the 43!
Old 06-01-2021, 11:02 AM
  #35
djprov431's Avatar
2021 C63S Coupe
You just can't really beat the deep V8 rumble.
hyperion667 (06-01-2021)
Old 06-01-2021, 11:03 AM
  #36
W205C43PFL's Avatar
I am sorry about the delay. I added some more information on the two clocks in the original post.
  #37
2012 CLS63
Few cars can compare Aston Martin maybe.
Old 06-01-2021, 11:09 AM
  #38
djprov431's Avatar
2021 C63S Coupe
added screen shots of the 63s shift light sequence above
Old 06-01-2021, 11:13 AM
  #39
djprov431's Avatar
2021 C63S Coupe
Interesting info, thanks!
Old 06-01-2021, 11:21 AM
  #40
superswiss's Avatar
2019 C63CS
Yeah, the clock is just IWC design. It's not actually an IWC clock. It's a digital clock that's synced to the car's clock, which itself is synced to GPS. All it has is an IWC looking analog face. An actual IWC clock is at a different level, and would probably be stolen constantly from the cars.
Old 06-01-2021, 11:30 AM
  #41
superswiss's Avatar
2019 C63CS
They might be slightly different in color as far as I can tell. Here's an older video (sorry it's German), but you can still him run through the gears around minute 1:20.
Old 06-01-2021, 11:33 AM
  #42
jhpmbusa's Avatar
2021 M550i
Do you get any pops and bangs when you emotion start the 63? with the 43 once it warms up, you can get a pop or bang out of it most of the times with the emotion start lol. Doesn't seem to pop on cold emotion starts though, just louder for sure.
Old 06-01-2021, 01:52 PM
  #43
djprov431's Avatar
2021 C63S Coupe
No, not on the 63 - sounds pretty much the same cold or hot IMO and with the Renntech exhaust module installed I just leave the exhaust flaps open 100% all the time....it's so much nicer. The only time I hear crackle on the 63 is if it's in sport + doing aggressive up/down shifts, or in Race going up or down.
Old 06-01-2021, 01:54 PM
  #44
djprov431's Avatar
2021 C63S Coupe
https://youtu.be/-k3Stmg7okU?t=4828
Yeah, that resembles what I see in the 43 -- not the 63. I'll get out and make another video of manual redline shifting in each car soon enough to show what I'm seeing. (funny, I saw that video some time ago )
Old 06-01-2021, 09:04 PM
  #45
djprov431's Avatar
2021 C63S Coupe
Uploaded new red line shift video to the top!
Old 06-02-2021, 11:40 AM
  #46
W205C43PFL's Avatar
Looks like AMG and IWC did collaborate on a real IWC watch
https://www.youtube.com/watch?v=-Irc...ature=youtu.be
Old 06-02-2021, 12:31 PM
  #47
djprov431's Avatar
2021 C63S Coupe
Ahh good find!
Old 06-03-2021, 12:45 PM
  #48
djprov431's Avatar
2021 C63S Coupe
I didn't even notice the keys were different between the 43 and 63s until today
Old 06-03-2021, 02:00 PM
  #49
superswiss's Avatar
2019 C63CS
Haha...that's usually one thing that keeps coming up. Yes, the 43 gets the regular key fob that all normal Mercedes vehicles have. Sort of gives away how the 43 has still one foot in the normal Mercedes camp, whereas the 63 gets the AMG key fob complete with the Affalterbach crest. Something that's coveted as signaling that it has its roots in Affalterbach with the engine and all. I'm not sure if the E53 and especially the GT43 and GT53 also get the normal key fob or if at least the GT43 and 53 get the AMG key fob, since they are from the ground up designed and built by AMG.
djprov431 (06-03-2021)
Old 06-03-2021, 02:43 PM
  #50
W205C43PFL's Avatar
Ah good find. Material wise, although the gloss black "looks" more premium, I prefer the matte finish because it is likely to scratch less.
Edit1: How did I forget the C63s is a C-Class ... I thought we are comparing C-Class and E-Class AMG keys. I didn't know the C63s gets the gloss black key as well (the same as the E-Class) I thought it would also be matte like the rest of the C-Class lineup just with an AMG logo. I guess that is MB to add value to the product (for getting the top of the line of C-Class)
Quick Reply: Owner review 2021 C43 & C63
