Humming Sound
Help!
https://mbworld.org/forums/c450-c43-...ea-20-c43.html
Edit: As the previous post suggested, can you please check the video and tell us if the sound is similar to that?
Thanks for the comments, been a busy week and I really haven't driven the car since posting. I did check the clip out from the other thread and its definitely not that sound.
I was able to capture it today, seems like it was intermittent. We came home after a 20 min drive, pulled on the driveway and I was able to hear it. It is definitely coming from the front, and it definitely louder when I lifted the hood up to grab video. We went for an even longer drive (60 miles) after I heard the hum on the driveway, pulled up, the wife and kiddo got out and there was no noise. As soon as they cleared the front of the car, it started up again. It sounds like its from the radar, but then again, first time I have owned a car with radar guided cruise so, I could be wrong.
https://imgur.com/a/zS8A2UV
https://mbworld.org/forums/c450-c43-...ing-sound.html
Unfortunately, the status of the issue was never updated by the original poster of the thread.
Just picked up the car, and well it appears that they have fixed it. We will see.
I played the audio I posted to the lead tech, and let him know where I was hearing the sound once I popped the hood. Lead tech took the car for a road test, and was able to confirm the same sound I was hearing. They were able to pinpoint the issue to the Boost Pressure Transducer (010-153-13-28). I was told it is an air pressure sensor for the turbo. Dealer replaced the sensor, and performed another road test where they confirmed that the sound was no longer being produced.
I was stuck in a drive thru for a while and I didn't hear it, and so Im hopeful, but only time will tell.
Thank you for your update on this thread and letting us know the results of the diagnostics and the repair (incl. part number) that was necessary to fix the issue. Although the issue is uncommon, I am sure your post will be helpful for anyone else that happens to have this exact same problem in the future.
Enjoy your car!
