C450/C43 AMG
*NEW* L.E.M MONSTER series: 3" high flow catted downpipes
Old Jun 21, 2021 | 05:12 PM
LogosMotorworks's Avatar
Former Vendor of MBWorld
S5,C450
Sometimes in order to remain competitive you need to evolve and improve. We would like to introduce our new 3" Monster series downpipes for the c400/c450 and C43.
Below are the prototypes with the highlighted differences from our standard Downpipes. We decided to evolve our DP's for several reasons from our (still awesome) standard DP's, and these will supersede our C43 downipes in our line.
>We wanted to compete with the style Supersprint currently offers as we have had requests from our German, Italian and Midde east customers to have something that connects directly to the Turbo Outlet V-band
> unfortunately we had our original designed copied, so we are evolving with this new design to stay ahead of the game
>we saw some room for improvement, as some Catless DP's connect to directly to the turbo v-band, so why not go ahead with that config.
>we tried to keep the price as accessible as possible in the category, accounting for the bigger catalyst and more material costs
THESE CAN BE PURCHASED HERE:>>
(And thanks to those who pre-ordered)
https://www.logosengineeringmotorworks.com/mercedes-amg
Construction:
  • Redesigned with 3" piping and a larger body
  • Deeper throaty sound with 15% more flow than our standard pipes
  • Entire Down Pipe is constructed out of rust resistant T304 SS for durability
  • Original Stock Downpipe is 3D scanned and reverse engineered for perfect direct bolt on fitment
  • Thick 8.5mm welds to prevent leaks or cracking
  • Argon gas back purged welds for penetration and seal =Long life
  • CNC T304 flanges, with connection directly to the Turbo outlet V-band
  • The only downpipe on the market that mimics the OEM design!! has sensor inside the catalyst, like original
  • 200 Cell high quality triangle matrix honey comb catalyst flows better than stock and competitors
  • Fully TIG welded construction, beautiful welds that can be seen!
  • Plug and play, no modifications needed,100% perfect fitment
  • Includes all hardware and bolts for installation
    Performance:
  • Get rid of that nasty smell that you get with catless downpipes and that awful "rasp" that come with de-cat pipes. Unleash a deeper, refined rumble: This is primarily due to the fact that engine pulse waves can expand in the barrel of the main catalyst body providing
  • Near identical performance to de-cat Downpipes, along with a throaty sound and without the smelly fumes.
  • turbo spools up quicker for better throttle response and unleashes up to 20 HP and 20 TQ
  • Quicker spool allows the power to come in earlier with being able to hold it longer
  • can allow you to go stage 2 on a tune to allow up to 30-40 more HP and Torque
  • re-map using JB4 data log and take advantage of the higher flow for that push you back into your seat thrust around 2500 rpm
  • Over engineered construction for years of use
Old Jun 29, 2021 | 11:21 AM
AVKT's Avatar
AMG C43
Will you release a version for right hand drive cars?
Old Jul 1, 2021 | 03:35 PM
1SickGLC's Avatar
2018 MB GLC 43 AMG
GLC, GLC, GLC
Old Jul 1, 2021 | 05:16 PM
S5,C450
@ AVKT: We are looking for a wholesale sponsor who would be willing to split a production run for RHD cars. The jig or mold for the US diver side is the same worldwide and across all c43 models: BUT> on RHD models Mercedes actually uses a GLC 43 downpipe that has a curve in it to clear the steering shaft.
@1SickGLC WE HEAR YA! :-)
Old Jul 19, 2021 | 06:11 PM
S5,C450
We want to thank everyone for their purchase, these sound sick on either exhaust system. please enjoy these revs from a car with the AMG performance exhaust , please wear headphones as they will provide a more accurate sound profile as opposed to coming out of a tiny phone speaker.
Old Aug 4, 2021 | 08:05 PM
S5,C450
have units in stock and ready to ship.
Old Aug 5, 2021 | 04:10 PM
S5,C450
I was asked by @Yuriy_Moscow what backs up our claim :
"Remember: no smell, no nasty honda civic high pitch rasp, and a deep exotic tone."
The answer is; our design is not unique in its engineering as this exists on other platforms as well, we went with what works. What makes ours different is that ours is a high flow catted design, that unlike a straight through "skinny" design has several acoustical advantages to the overall tone of the downpipe. Without getting too technical about harmonic resonance, the principal is simple if you compare a downpipe to a musical instrument where varying diameters of tubing affect the tone and pitch. See the below picture for a visual representation.
The same principal exists with your cars resonator, its just a void that allows certain sounds to expand and cancel out certain frequencies. the catalyst also acts as a acoustic dampener for higher pitched frequencies as well.
Our B58 downpipe for the BMW has the largest barrel body on the market today (5") and we chose this not only because of flow but because of sound and expansion. it also has a 200 cell catalyst on the inside.
a good example is this video on you tube of the revs of a catted and uncatted downpipe for the n55 engine (straight 6, turbo charged), the tone and sound difference is clearly there (best heard with headphones)
compare this to our 5" high flow catted downpipe for the B58 within our "Monster" series line. More bass and smooth tone compared to no cats:
e
Old Aug 5, 2021 | 04:14 PM
S5,C450
@paj and @Mineral43_ do you guys have rasp or buzz with our DP's ?
Hows the sounds so far?
Old Aug 5, 2021 | 04:36 PM
LBarto's Avatar
Mercedes C43 AMG
Does this also come in an RHD configuration? And would you expect to see roughly the same gains as a decat?
Old Aug 5, 2021 | 05:26 PM
SilverBullet18's Avatar
C450,GLC 63,VW GTI
I have these and can attest that everything stated about the sound and performance is correct. I had no name catless pipes on for a very short while and the sound was disgusting quite frankly.
Old Aug 5, 2021 | 06:02 PM
BidAsk132's Avatar
GLC 43 AMG
very reassuring to hear. Going to wait for a batch for my GLC 43 before I go stage 2
Old Aug 5, 2021 | 07:14 PM
paj's Avatar
paj
17 C43 AMG
None what so ever! Deep throaty sound!
Old Aug 7, 2021 | 04:21 AM
Yuriy_Moscow's Avatar
C43 AMG 2018 (facelift)
https://www.youtube.com/watch?v=NDCKUBNzHQA
https://www.youtube.com/watch?v=__rzoChoo38
e
Wow, thanks for such an open answer. If it solves the issue with raspy sound that every C43 gets with decatted pipes, than you have created an amazing product!
Old Aug 7, 2021 | 07:22 PM
Rextc's Avatar
2017 AMG C43
Need these in RHD please.
Old Aug 8, 2021 | 10:08 AM
dowheelies's Avatar
too many...
How simple is the install? Any write up or instruction? Nowhere as intense as my E63 was I would hope/think.
Old Aug 8, 2021 | 12:02 PM
S5,C450
The DP's are plug and play. We had several customers do the install in their garage. The install is wayyyyy easier than the C63 E63 downpipes, if purchased we can send you a document that details the install. Its not a super a comprehensive write up but enough to get the job done.
As long as you can jack up the front end of the car and keep it up using jack stands, you're already 1/4 way there.
Old Sep 18, 2021 | 06:04 PM
S5,C450
new batch made. These are in stock and ready to ship! so far almost every left hand drive continent has a pair.
Old Sep 20, 2021 | 08:46 PM
BoolitSpunjBoon's Avatar
C450 AMG
Looking to order these. Will these cause a CEL?
Old Sep 22, 2021 | 07:16 PM
S5,C450
@BoolitSpunjBoon depending on your configuration. We will recommend a specific 02 spacer that keeps the CELs away and a couple of folks here have used it without a CEL's.
Alternatively you can tune it away with a ECU tune.
Old Oct 4, 2021 | 10:56 AM
allanyeung99's Avatar
2017 Mercedes C63s
I would get a tune for these downpipes because the stock ecu is programmed for stock downpipes. So in result, your car may lose some hp or may not perform as well as stock.
Old Nov 10, 2024 | 04:59 PM
ImSwirled's Avatar
2017 C43 AMG Sedan
What 02 spacers would i need? I have monster pipes and want to add 02 spacers.
what brand or type
