Facelift exhaust valve bypass/delete
thanks!
Apparently, when the car shuts down the valves open up. Thus, when you shutdown the car and install the module it won't receive the signal to close. The valves will stay in the opened position persistently.
disconnect the kuester actuator from the exhaust
disconnect the actuator from the wiring
tuck and route the wiring back into the trunk next or near to the kristonics valve computer.
reconnect the actuators and secure them/ tape them down so they wont flop around. This will ensure no error code because its still technically connected.
done.
your actuators will still work or do their thing inside the trunk because the car still thinks its connected, but whatever. Now your exhaust flap is open 100% of the time for free.
the kristonics unit is under the carpeted section of the trunk
thanks!
done.
You need two.
I have a 2019 - W213
when I shut off the car I used to hear a chirp, took to dealer under warranty and they replaced the whole rear exhaust on the left side ($3000) in order to replace the bad flapper, this solved the issue. However now a few months later (out of warranty) the car is making a low chirping sound while idling coming from the flapper.
When I put in S+ mode I hear the flap open and the noise stops. These things are junk.
does anyone have any reliable way to force these open all the time or delete all together?
After waiting 15mins for the ECM to fall asleep it only took 10 mins to install! Starting up this morning the car sounded Great!!
Anyone thinking about this should really just do it!
