C450/C43 AMG
No boost with jb4
Old Mar 30, 2023 | 09:48 PM
godson960's Avatar
c43
No boost with jb4
Hoping I can get some help I have a 2019 c43 with a jb4 . I had it on for about 7-8 months then out of nowhere I would lose boost . I would have to shut the car off then back on again then it’s back to normal . Just recently it was so back the car shut off in traffic . At the time I didn’t think it was the jb4 but I had it at Mercedes 4 times with a total of 3 weeks altogether down time . They replaced everything including both turbos and spark plugs of course. The guys at bms sent me out a new board and having the same issue …. They did say it could be a misfire but there no way 2 sets of plugs are bad … I’ve tried every map and still the same
fyi : people say the jb4 can be detected if they dig deep but they actually flew someone out to look and work on my car (supposedly) and changed out the whole engine plus miscellaneous items so anyone thinking of a jb4 being detected I’m not so sure and my warranty is intact
Old Mar 31, 2023 | 12:53 AM
MaverickC43's Avatar
Amg C43
Any codes?
Old Mar 31, 2023 | 12:57 AM
Amg C43
Map 0 too?
tried logging while it happens?
I’ve had similar issues a few times
and just want to pull over to restart car as soon as I can.
this week engine light came on but jb4 read no codes
Old Mar 31, 2023 | 12:58 AM
Amg C43
Dealer replaced turbo?
was the car still not boosting when u took it in??
Old Mar 31, 2023 | 07:44 AM
godson960's Avatar
c43
no codes or lights … everytime after repair same thing even on map 0 . As long as the jb4 is hooked up I get intermittent boost and have to restart the car.
and no haven’t logged since it first started but it’s just weird how it worked fine for months and just switched up like that . Before all this happend I did send logs for map 6 and was told they were good by bms and after that never changed a setting or modified anything on the car. The dealer couldn’t figure it out either even after replacing anything
Old Mar 31, 2023 | 07:57 AM
Amg C43
It’s not a grey sedan is it?
Old Mar 31, 2023 | 08:37 AM
godson960's Avatar
c43
no 😂
Old Mar 31, 2023 | 09:13 AM
Amg C43
That’s soooo strange.
Bad connector. Or frayed wire or loose pin but clearly it’s the connection of the jb4 unit. And so annoying
sorry man I hope things get figured out soon!!!
Old Mar 31, 2023 | 12:22 PM
C43 Fun Haver's Avatar
2015 ML63
Have you left the Jb4 unplugged from all connection points, reconnect original sensors. Same issue? I was running into this on my C43 but got rid of the car before I even looked into that issue i was having. do you know if they replaced the pressure transducer? Part number A000-153-18-00
Old Mar 31, 2023 | 12:45 PM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
This has intermittently been happening to me as well. I don't know what's causing it or a solution, but I did narrow down the point at which the boost drops off for me. Just after taking the onramp on the highway for my commute, somewhere within the first mile or so when I'm travelling between 70-77mph. Exact same thing...car drives fine, no codes, just no boost. Technically JB4 log shows .5-1.5psi under full throttle, but that's essentially nothing. A quick power down and start up and it comes back alive for the rest of the day. Some days it happens, most days it doesn't. Happened before switching to LEM intakes, and has persisted. Completely unpredictable when it happens though.
Old Mar 31, 2023 | 12:48 PM
Amg C43
@BMS @Terry B help
Old Mar 31, 2023 | 12:53 PM
Amg C43
Have u been logging ever when it happens?
Old Mar 31, 2023 | 01:26 PM
I've tried a handful of times when I think it might happen, but inevitably never does!
Old Mar 31, 2023 | 03:15 PM
2015 ML63
It only happened to me after a hard launch at like 2400-2600 rpms i wanna say, not regularly driving around town. From what you said it sounds like a mile after the on ramp @ 70-77.. are you coasting up to those speeds are driving like you stole it n letting off?
Old Apr 1, 2023 | 09:57 AM
thegreyone's Avatar
C450 & 335i 740whp
Buy one of these vacuum valves next. If yours is gunked or failing You will start to get issues.
Low boost/slow response fix for C43 C450 and the C400. Vacuum pump valve fix for M276 - YouTube
Old Apr 1, 2023 | 03:11 PM
Never happens in the middle of heavy acceleration…like maybe 5-10mph acceleration to pass or just pace away from someone. No more than 50% throttle I’d guess.
Old Apr 1, 2023 | 03:14 PM
Very interesting! Seems easy enough in the video. I’ll check it out. Wish he included a p/n or link tho!
Old Apr 1, 2023 | 03:44 PM
thegreyone's Avatar
C450 & 335i 740whp
There are some cheaper quality valves on ebay, but i didnt want to chance it. I went with the higher quality valve below, the only issue was its shipping from kyiv, ukraine so It took nearly a month to arrive, but here it is:
Klifex Vacuum Pump Repair Kit For Mercedes M276 W212 W205 W166 2762300065 (amazon.com) Klifex Vacuum Pump Repair Kit For Mercedes M276 W212 W205 W166 2762300065 (amazon.com)
Old Apr 3, 2023 | 12:46 PM
Amg C43
What has jb4 support said to you guys?
Old Apr 6, 2023 | 04:46 PM
godson960's Avatar
c43
Yes they replaced 4 pages worth of stuff the transducer was the first visit
Old Apr 6, 2023 | 04:51 PM
godson960's Avatar
c43
yes I have hopefully you guys can see it
Old Apr 6, 2023 | 04:54 PM
godson960's Avatar
c43
was told to gap to 0.25 but the same thing is happening and these are the 2nd set of plugs
Old Apr 6, 2023 | 08:42 PM
Cosworth2000's Avatar
2022 E53 AMG
In order to find out if this is part of the JB4, remove it from your car and plug in all the OEM plugs. Once you have done this, remove the power (negative) and let the car sit with the keys far from it so the modules all go to sleep. That will take about 15 minutes as they eat up any left over power in the system.
Now that your car is reset, drive it for the new couple of days. If the problem does not show again, then the JB4 is causing the problem however if the problem persist then the bad news is that your PCM is faulty.
Old Apr 6, 2023 | 08:59 PM
godson960's Avatar
c43
I actually did this 2 times once with all oem plugs plugged up and the 2nd time did the battery disconnected over night over a 5-7 day span cause I sent my jb4 back while I waited for my new board . The car runs fine and hard without the jb4 it’s scheduled for the dealer for 5th time if this doesn’t work corporate said a buy back or newer model is on the table . It sucks cause I really like the car
Old Apr 6, 2023 | 09:04 PM
2022 E53 AMG
Okay, just don't tell them that you tuned your car.
If the car runs good without the JB4, I would agree, that is the issue. You are lucky you live in the USA because here in Canada, we would be stuck with the car and you can only send it back and forth, over and over again.
