C43 stock/sport exhaust question
Hi guys! So I have c43 2019. Love it! Only problem is that i bought it without PE exhaust(pe button).
i love the sound of the car when it opens flaps at 4000+ . No need for louder exhaust or something. Only problem is below 4000 rpm, when i am cruising or if i want to rev the car in idle.. no sound.. is there anyway to have open flaps all the time on stock exhaust? I would love to hear the car all the time and not only when driving hard. I think that pe has electronic flaps, but sport exhaust (mine) has pressure based.
thank you!
thank you!
Retrorog (01-23-2024)
Received 2,842 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
thank you!
thank you!
Your non-PE does not have values. Its just a basic exhaust so you can't do anything except upgrade your exhaust. A good one is AWE as all the others are way to expensive.
Received 3,997 Likes
2019 C63CS
As the thread linked by @W205C43PFL discusses, the PE requires an exhaust module in the trunk that controls the valves, as well as a new wiring harness for the button to control the valves from the center console and coding it in, so that the exhaust is properly controlled based on the current drive mode. The PE is integrated with AMG DYNAMIC SELECT, so it isn't just a different sounding exhaust. The author of that thread if you read it essentially ended up just bolting on the PE w/o valve control and basically kept the valves open at all times. That's certainly an option, but it's not how the PE is designed to work.
The non-PE exhausts are not valved, so the exhaust button in the center console and exhaust control in AMG DYNAMIC SELECT is not there, nor is the module that controls the PE as said.
Hang on a bit, in my C43 non-PE, there's a clear difference in how the exhaust sounds in Comfort vs Sport vs Sport+. On Sport+ I even have pops and bangs and it's clearly louder. So the non-PE exhaust is also integrated with the AMG Dynamic Select. Also when starting cold the sound is pretty loud in any mode (valves open), then after 1-2 min. it gets quieter (valves close). This for me is a clear indication that the standard non-PE exhaust also has controlled valves. The question is how and if there's any option to keep them open at all times.
Hang on a bit, in my C43 non-PE, there's a clear difference in how the exhaust sounds in Comfort vs Sport vs Sport+. On Sport+ I even have pops and bangs and it's clearly louder. Also when starting cold the sound is pretty loud in any mode (valves open), then after 1-2 min. it gets quieter (valves close). This for me is a clear indication that the standard non-PE exhaust also has controlled valves. The question is how and if there's any option to keep them open at all times.
Could you do us a favour and actually look inside your exhaust if there are valves at all? You got me curious.
Retrorog (05-19-2024)
2019 C63CS
Pops and bangs and such are not generated by the exhaust. They are generated by the engine ECU by changing the ignition timing. Specifically, the combustion is extended past the cylinder exhaust valves opening, so fuel burns inside of the exhaust causing the pops & bangs. Sport+ also raises the idle rpm, so making things louder even at idle and you are generally in lower gears and at higher rpm in Sport+.
I'd be surprised if all that would be done by the ECU alone. And I was saying, it simply gets louder overall in Sport and louder still in Sport+. On cold start it's not related to the engine RPM, you can actually feel the difference when the sound changes and gets quieter. I'll look inside and let you know.
And when I say louder, it's any RPM, not just idle, it's across the band.
LE: just looked - no valves that I can see, there's only one pipe each side and there's nothing inside that I could see.
2019 C63CS
It's been reported multiple times that there are no valves in the non-PE exhaust, and even confirmed as far as I know. The non-PE exhaust also doesn't have an H-pipe. Although the C43 PE doesn't have a valve in the H-pipe, only the C63 does. The C43 PE has only left and right muffler valves.
You would see the valves when looking inside the exhaust if there are any.
One of the older threads: https://mbworld.org/forums/c450-c43-...ust-valve.html
2019 C63CS
Also, don't forget there's sound being pumped into the cabin through the speakers and it's louder in Sport and Sport+.
No, I'm not talking about the pumped sound, you can hear that it comes from the outside when the window is a bit down and/or driving past a wall or in a tunnel. I'll try capture it on video and if I get a good result I'll post it here. If it doesn't have valves, then I'm really curious how the sound changes so much.
The following 2 users liked this post by C43HeartBoost:
Retrorog (12-07-2023),
superswiss (04-11-2023)
I guess that confirmed it and answered our question.
Lol that was a long and painful read... So considering I have a FL estate with PE..... I can correlate that to what was said in that post which is that nobody has a clue about whether or not sound is plumbed in 😂
I'll take a look and see if there's a fuse or not...
Ya, I mean given an estate is fully opened, the exhaust is loud enough to not be pumped in I think? Same reason some people drop their seats of the sedan and it sounds louder.
Ya I don't see the fuse in question, you might not have it or it might be in a different fuse box. Curious though, most people get ASR, CETE is certainly not talked about often, what made you pick CETE over ASR?
