Permanent 12V location
Hello guys. I need to connect a dashboard camera with parking surveillance on my w205 2016 C43 AMG to a permanent 12V power delivery. Please help me out !
i need to connect 3 wires ! I post picture !
VCC+ ACC GND-
VCC+ ACC GND-
Received 2,842 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
There isn't one, you can hardwire, however. The three wires is part of the hard wire kit, not the 12V socket.
Or, you could buy a dashcam battery (Please don't just use a power bank/battery pack as they are designed differently, and last you need are batteries exploding in the car because it wasn't designed for the purpose).
https://mbworld.org/forums/c-class-w...ssue-help.html
https://mbworld.org/how-tos/a/merced...ash-cam-384227
This is a dashcam battery: https://www.blackboxmycar.com/collections/battery-packs
If you don't want to use a dashcam battery, here are some hardwiring options:
https://www.youtube.com/watch?v=tXcQXY_LUaU
https://www.youtube.com/watch?v=uBhX5yjdoxk
I already answered your question, there are no permanent 12V available in this car, you have to hardwire it, it will provide constant power even if your engine is not on and shuts off when your starter battery gets too low to the point there is a risk of not able to start the engine (ie. not enough cranking voltage).
PROBLEM FIXED !!!!!
The RED WIRE fuse 219
The YELLOW WIRE fuse 204
And the parking surveillance function WORKS !!!
I hope this information will help other users !!!
WVM (08-27-2023)
