C43 AMG weird engine sound
Subscribe
Dec 7, 2023 | 03:09 AM
Hi.
I'm South Korean.
I'm riding the C43 AMG model(W205)
There isn't much information about this vehicle in Korea, so I'm trying to get help from the forum here. A week ago the engine started making strange noises. Is there anyone who has experienced the same sound or symptom as mine, or has solved this problem?
I am attaching a video that will help you guys solve the problem with this vehicle.
Please help me
Thank you.
Reply 0
Dec 7, 2023 | 04:02 AM
Quote: Hi.
I'm South Korean.
Please help me
Thank you.
not having any success opening the file attached assuming it is an archive can you upload to youtube and link it over?
Reply 1
Dec 7, 2023 | 04:34 AM
Finally able to open your file sounds like the Pressure Transducer, pretty common but cheap and easy repair. See and listen to the videos in this thread if it sounds similar to yours. https://mbworld.org/forums/c450-c43-...nge-sound.html
https://mbworld.org/forums/c450-c43-...ml#post8362324
https://mbworld.org/forums/c450-c43-...ing-sound.html
Edit: Added more links of the same problem and sound. Is it the sound you are hearing?
Reply 1
Dec 7, 2023 | 07:35 PM
here is the link
Reply 0
Dec 7, 2023 | 09:02 PM
Quote: Finally able to open your file sounds like the Pressure Transducer, pretty common but cheap and easy repair. See and listen to the videos in this thread if it sounds similar to yours. https://mbworld.org/forums/c450-c43-...nge-sound.html
Thank you for links and advice
It is similar but, the sound is little bit different with my engine noise.
I will open the car bonnet, take a video, and upload it again.
Reply 0
Dec 7, 2023 | 09:26 PM
I see, if you can pinpoint the approximate location, forum members like us might be able to help, your grille is a custom grille right, just want to make sure you have a W205 and not the new W206.
Reply 0
Dec 7, 2023 | 09:29 PM
Hmmm, unless I am missing something but that car does look like a W206, I don't recall ever seeing that type of blue on a W205, might be my device making the blue look different though.
Reply 0
Dec 7, 2023 | 09:32 PM
Hmmm, so I went on your country's site for some reason I couldn't find the W206 C 43, surprised it wasn't sold there? In that case, pretty much confirmed your car is a W205, but then that blue though. Let me try a different device, might be some sort of screen filter on my phone causing the blue to look different.
Reply 0
Dec 10, 2023 | 09:37 PM
Quote: Hmmm, so I went on your country's site for some reason I couldn't find the W206 C 43, surprised it wasn't sold there? In that case, pretty much confirmed your car is a W205, but then that blue though. Let me try a different device, might be some sort of screen filter on my phone causing the blue to look different.
I tried to take a video by opening the car bonnet, but the noise disappeared, perhaps because the weather was warm recently.
But this morning I noticed the sound again.
The W206 model was released late in Korea. I am driving a W205 model.
The color appears a little more blue because of the cell phone camera lens.
I'll take a video again and upload it when the noise comes back.
Thank you so much for your interest.
Reply 0
Dec 11, 2023 | 08:16 PM
Quote: I tried to take a video by opening the car bonnet, but the noise disappeared, perhaps because the weather was warm recently.
I see, that explains why I can't see the car on your country's site.
You're most welcome, all trying to help. Hopefully your new video will provide us all some insight.
Reply 0
Dec 12, 2023 | 08:48 AM
To me it sounds like something is loose and rattling. You need to find where in the engine department the sound is coming from as from the outside of the car, it will be harder to track down.
Reply 0
Dec 13, 2023 | 01:34 AM
OP, is the sound audible when all doors/windows are closed and when you are in the cabin? Is the sound ever present when revving on a standstill or when driving?
Reply 0
Dec 13, 2023 | 02:37 AM
Quote: To me it sounds like something is loose and rattling. You need to find where in the engine department the sound is coming from as from the outside of the car, it will be harder to track down.
Thank you for your interest.
I'm still waiting for engine noise comes back.
I will upload a video today as possible.
Reply 0
Dec 13, 2023 | 02:46 AM
Quote: OP, is the sound audible when all doors/windows are closed and when you are in the cabin? Is the sound ever present when revving on a standstill or when driving?
When I start the car and the engine heats up to a certain degrees. It starts making noise.
Even if all car doors and windows are closed, sound still slightly enters the car.
There is no engine noise while driving, and it only make a sound when stopped.
Also, when the engine is fully heated. there is no sound
Reply 0
Dec 13, 2023 | 09:26 AM
Quote: When I start the car and the engine heats up to a certain degrees. It starts making noise.
Is the sound there if climate control is not set to recirculation (can you clearly hear it also piping through the vents?), asking because the fan outside will open its cover for fresh air which then some sound might enter the cabin that way.
Reply 0
Dec 14, 2023 | 03:50 AM
Quote: Is the sound there if climate control is not set to recirculation (can you clearly hear it also piping through the vents?), asking because the fan outside will open its cover for fresh air which then some sound might enter the cabin that way.
I turn off my car air conditioning system most of the time.
Noise is heard from the top of the engine. It seems to be the turbo line.
I really don't know where the sound is coming from.. This noise really bothers me..
Reply 0
Dec 14, 2023 | 04:29 AM
I uploaded the video again.
I can't hear the sound very well.
There is a slight noise for about 30 seconds, but I don't know if you can check it.
Still, I would be very grateful if you could watch it.
Thank you so much for being so kind.
This is the link!
Reply 0
Dec 14, 2023 | 08:18 PM
This is the link!
https://youtu.be/DLYVhbs6QuQ
Engine oil level confirmed is correct? Are you talking about the rapid tapping/ticking sound when you point your camera towards the right side of the engine?
Reply 0
Dec 14, 2023 | 09:45 PM
I think I hear what u don’t like.
I think a lot of our cars make strange noises
mine ticks louder
Reply 0
Dec 14, 2023 | 09:48 PM
But it gets better when it’s warmed up🤷🏻‍♂️
Reply 0
Dec 14, 2023 | 10:32 PM
Quote: Engine oil level confirmed is correct? Are you talking about the rapid tapping/ticking sound when you point your camera towards the right side of the engine?
I did not check the car engine oil level. I will definitely check it out today.
ah! I'm not talking about tapping/ticking sounds.(Is the engine sound strange? I feel like this part is not much different from other engine sounds.
I know it is difficult to determine what the problem is unless you directly see the engine condition.
I plan to go to the repair shop soon for an inspection.
Once I figure out this problem and solve it, I will post what the problem was here on the forum.
Lastly, I will link one more video.
Thank you very much. I hope you are always healthy and happy.
This video also watch from 30 seconds onwards.
Reply 0
Dec 14, 2023 | 10:37 PM
mine ticks louder
Try to watch "MB World Forum 2" 30secs onwards.
Reply 0
Dec 14, 2023 | 10:42 PM
Quote: I did not check the car engine oil level. I will definitely check it out today.
https://youtu.be/GXciSbAe4Vg
The injector ticking is making hearing it very difficult but interesting sound indeed as it sounds like a diaphragm moving after the 30 second mark you mentioned.
Reply 0
Dec 15, 2023 | 03:06 AM
Quote: The injector ticking is making hearing it very difficult but interesting sound indeed as it sounds like a diaphragm moving after the 30 second mark you mentioned.
Yes, it is really strange noise.
Reply 0
Dec 15, 2023 | 04:07 AM
Quote: Yes, it is really strange noise.
Hmmm, you checked the pressure transducer and it is not at all that right (I understand you mentioned it doesn't sound exactly like the other threads I linked)? Does it happen when engine is first started cold or only when warm? I remember in a previous post, you said it is not there when warm, so it might be trim related, could it be some plastic expanding and making contact under the hood when it is warm?
Reply 0
