C450/C43 AMG
Another strange sound
Old Feb 7, 2022 | 08:51 PM
MaverickC43's Avatar
Amg C43
Any ideas
not really anything to watch just the sounds
Attached Thumbnails Another strange sound-125f5c94-9bbd-40e8-8ec8-55213a5c8163.jpeg
Old Feb 7, 2022 | 08:52 PM
Amg C43
Originally Posted by MaverickC43
Any ideas
here they are
File Type: mov
File Type: mov
Old Feb 7, 2022 | 09:40 PM
W205C43PFL's Avatar
here they are
Ah sounds familiar, sounds like air is trapped it is an uncommon issue but easily resolvable.
Do you notice any coolant leak?
Some forum members were able to get it fixed by simply replacing the coolant cap others need to replace the pressure transducer.
Old Feb 7, 2022 | 10:26 PM
BayAreaAMG's Avatar
2016 C450 AMG
here they are
Wastegate solenoid. I've seen many posts about this problem before. I think I've mentioned it to you by pm once, about the sound made during idle.
This is the part and it's super easy to replace. But listen to this area on your car see if you can feel vibration or sound coming from it.
new part # is this one:
Old Feb 7, 2022 | 10:30 PM
W205C43PFL's Avatar
Thanks for confirming it is indeed the pressure transducer along with the position and the part number, I thought I remembered it wrong.
Old Feb 7, 2022 | 10:38 PM
BayAreaAMG's Avatar
2016 C450 AMG
Yw, I'd recommend to confirm it even though I'm 99% sure that's what it is based on the sound it's making. I've seen close to a dozen posts on fb about this problem and they all sound the same
Old Feb 7, 2022 | 10:51 PM
W205C43PFL's Avatar
I am pretty sure you are right and that is the culprit. I remembered somewhere along the lines of pressure transducer but I couldn't find the post where it was mentioned so I was doubting myself until you chimed in (thank you) and now I found it:
https://mbworld.org/forums/c450-c43-...ml#post8362324
This forum member had it replaced by the dealership and problem was resolved.
Old Feb 7, 2022 | 11:34 PM
BayAreaAMG's Avatar
2016 C450 AMG
oh yea that's it, that post is exactly the same sound and problem. Luckily even if someone was out of warranty it's about $120 for the part and less than one hour to replace. That part is the wastegate solenoid which is what the ECU switches on and off to regulate boost. There's a vacuum line going into it from the vacuum pump, then one line out which splits to the two turbo wastegates.
It's odd to see so many posts about this problem, and it appears that Mercedes has changed part numbers twice
Old Feb 8, 2022 | 02:52 AM
Amg C43
Got it
thank you guys !!!
Old Feb 8, 2022 | 06:31 AM
Amg C43
So I should make the dealer focus on the solenoid not the coolant system or do they work together ?
thx
Old Feb 8, 2022 | 09:16 AM
W205C43PFL's Avatar
Hmmm ya especially how OP in the link I linked you has a facelift 2020. My 2017 don't have this problem... yet. Maybe I might had jinxed myself lol? Thanks again for chiming in with all this detailed information and to explain how it works and the function of it I am sure others will find this information useful. Enjoy your car!
Old Feb 8, 2022 | 09:40 AM
W205C43PFL's Avatar
thx
Some that have coolant leaking around the cap area fixed this sound by replacing the coolant cap. It is because the suspected cause was air trapped in the coolant system but then it is probably not the true fix, the pressure transducer that forum member BayAreaAMG mentioned is the true fix.
Anyways, here is the thread that I was able to find again where OP there mentioned it was fixed by a coolant cap, I am seriously curious if it came back though (OP there did mention it didn't come back since for a few days but not sure if it then reappeared but thread wasn't updated after a few weeks for example):
https://mbworld.org/forums/c450-c43-...ml#post8450423
My advise since you are under warranty, get the dealership to replace that transducer for a more effective and permanent fix plus like forum member BayAreaAMG mentioned, it is a cheap and easy thing to replace even if you are actually out of warranty.
Old Feb 8, 2022 | 10:18 AM
Amg C43
I will keep u posted
Old Feb 8, 2022 | 10:19 AM
W205C43PFL's Avatar
Sounds good, let us know the outcome.
Old Feb 8, 2022 | 11:51 AM
Amg C43
It’s not doing it all the time.
is that what others are hearing??
Old Feb 8, 2022 | 03:35 PM
BayAreaAMG's Avatar
2016 C450 AMG
Yea the leaky coolant cap is a separate but common issue on these cars. I had leaking coolant from the main reservoir, replaced the reservoir cap and corrected the coolant levels (dealership overfilled it) and never had the problem since.
I imagine the wastegate solenoid problem can be intermittent. The solenoid is just an electromagnetically controlled actuator that act as an on/off switch for the vacuum going into to the wastegate. To me it sounds like it's becoming partially open and closed at idle when it should be closed, but not sure
Old Feb 8, 2022 | 03:38 PM
Amg C43
And I just got the car back from the dealer and the coolant cap is leaking.
Prob overfilled
Old Feb 8, 2022 | 03:45 PM
BayAreaAMG's Avatar
2016 C450 AMG
Mine was overfilled by a decent amount, left a nice stream of coolant on my garage floor a couple days later after the service. I guess that's when the cap finally gave out.
Old Apr 17, 2025 | 02:41 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
coolant extreme heat/pressure
The coolant cap has a built-in pressure relief that protects over pressure in the whole cooling system.
When it opens coolant goes down a discharge conduit built into coolant tank.
> Tips for this hot topic ...
-- What's causing coolant to over pressure cap ??
Extreme heatsoak of engine head at engine stop.
-- What causes extreme heat to accumulate ??
Heat not being removed as it's being produced.
-- How not to get extreme heat ??
Its a normal stock condition to save gas with dry pistons.
To prevent extreme heat, pistons need to be spray-cooled at normal driving Rpm.
Old May 9, 2026 | 04:11 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Reviving an old thread to ask if the boost control solenoid can be defective and not throw a code? I have zero boost but car drives normal minus power and boost. No check engine light. I’m suspecting this might be the issue along with a bad vacuum pump valve.
Old May 9, 2026 | 04:24 PM
W205C43PFL's Avatar
Do you hear the goose/honking sound? Bad vacuum check valve usually results in low boost but not completely no boost but still worth checking though.
