C43 AMG transmission wont engage drive, how cooked am I
Today, driving along fine, get home, try and park, put the car in reverse to get into the driveway, and the car jerks while stationary, move a little bit in reverse and it moves to neutral, try and go to drive and it moves to neutral happened about 4-5 times before it let me and then a check engine light comes on after i restart the car. I used by scanner it it threw a p073e code, and it says car can't engage reverse on the scanner. Unsure when the last transmission service was done but I've only owned it for about a few months now, Would getting a transmission fluid flush and change relieve this? Also what are the costs I can expect for that service.
I haven't had any issues shifting (my dumbass forgot to mention that in the original post) ,and car goes through gears nicely, I only have problems when going from park - drive - reverse. I will head to a shop and get a diagnostic done, here's to it being only fluid!
Also I've noticed you a lot on this forum you contribute a lot! Thanks!
