C450/C43 AMG
C450/43 AMG engine capacity
Old Mar 26, 2025 | 01:34 PM
RamiZein's Avatar
C450/C45 2016
Hello guys. So apparently my oil change took around 7.5 to 8 liters of oil in the engine. The car is a c450/43 2016. Is there anything i should be concerned of or is that normal? The car is not doing anything weird
Old Mar 26, 2025 | 02:21 PM
W205C43PFL's Avatar
Manual calls for 6.5L but throw you VIN on lastvin and mb.vin, look for something called oil offset amount.
Old Mar 26, 2025 | 02:22 PM
W205C43PFL's Avatar
That said, 8liter is a bit too much, I would siphon some.
Old Mar 27, 2025 | 08:24 PM
RamiZein's Avatar
C450/C45 2016
OIL OFFSET AMOUNT +1000 ML OIL
what does that mean
Old Mar 27, 2025 | 10:03 PM
DamianPerth's Avatar
2018 C43 AMG
what does that mean
yes, offset means add or subtract from what the manual specifies. I just did my oil yesterday and at 6.5L (manual specified) am only midway to max. I’m checking my vin this morning and expect it’ll have a +### offset for me to add to get it properly full.
Old Mar 27, 2025 | 11:06 PM
W205C43PFL's Avatar
what does that mean
As mentioned, not all M276 is created equally and therefore requires a different amount of oil hence why this amount is mentioned on the data card.
Old Mar 27, 2025 | 11:07 PM
W205C43PFL's Avatar
I seen C 43 that only has 350ML oil offset amount for example so that was interesting.
Old Mar 27, 2025 | 11:09 PM
W205C43PFL's Avatar
Oh it was 0.3L not 350ml I was talking about: https://mbworld.org/forums/general-m...does-mean.html
For reference, my 2017 C 43 has the same +1000ML oil offset amount.
Old Mar 27, 2025 | 11:11 PM
W205C43PFL's Avatar
@KristiyanPetrov , just want to bring you to this thread, here is another forum member that has a +1000ml oil offset amount. not sure why yours is 0.3L, we have pretty much the same cars
Old Mar 27, 2025 | 11:57 PM
2018 C43 AMG
yep, just confirmed mine: A035 OIL OFFSET QUANTITY +350GR OIL
Old Mar 28, 2025 | 06:58 AM
W205C43PFL's Avatar
Same as the other forum member.
Old Mar 28, 2025 | 09:20 AM
Manny_c450's Avatar
C450
Mine also shows +1000ML
It is also a 2016 C450 so I usually pour around 7.5-7.75 Liters.
Old Mar 28, 2025 | 09:58 AM
W205C43PFL's Avatar
But... OP's 8L is too much, no?
Old Mar 28, 2025 | 10:59 AM
Manny_c450's Avatar
C450
Yeah maybe he can drain some out (300ML) or so.
Old Mar 28, 2025 | 03:08 PM
W205C43PFL's Avatar
Old May 9, 2025 | 08:49 PM
W205C43PFL's Avatar
https://mbworld.org/forums/w212-amg/...ml#post9074484
Old May 10, 2025 | 11:52 AM
Cosworth2000's Avatar
2022 E53 AMG
I have changed my oil on my W205 C450 many times on my own and I always added 6L but on the 0.5L, I would use the dip stick as my measurement. The extra is to make sure that the oil filter is filled as it's on top of the engine. So add 6 and use the dipstick to measure, start the car and revv to 2000 rpm. Check the oil again and add if needed.
Old May 10, 2025 | 12:00 PM
W205C43PFL's Avatar
Yes the 6.5L includes the filter, thing is there is the oil offset amount. I find that when I fill it at the 6.5L by book no matter how I measure it, it is always close to the min mark. Measure it overnight, measure it by the operator's manual instructions, measure cold, measure it warm. Ever since I learned about the offset amount on the datacard, the oil level is constantly kept at above middle of the dipstick but below maximum mark, more like in between the middle and max mark now.
Old May 10, 2025 | 12:01 PM
W205C43PFL's Avatar
By book https://cimg6.ibsrv.net/gimg/www.mbw...2ad059dc1e.png
Old May 10, 2025 | 12:02 PM
2022 E53 AMG
For me, I just make sure that it's the what the book says, then I use the dipstick afterwards and follow that as my guide.
W205C43PFL's Avatar
Yes I pull and wipe then push and pull and yes at leveled surface, clearly, this oil offset amount on the data card does mean something.
Old May 10, 2025 | 12:04 PM
W205C43PFL's Avatar
Good to hear it works for you, to be honest not a lot of people check the data card when filling oil so clearly MB thinks it is not that big of deal and don't mention it specifically in the operator's manual for example. Thanks for commenting.
Old May 13, 2025 | 07:37 AM
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
wow it seems i didn't saw the notification that you've tag me
i do notice some ppl have offset 1l others 0.3l as me but but but last 2 oil changes i did myself instead on Dealer and i notice when i pour 7l and i start the car and then i turn it off oil lvl is on the bottom of MIN but if i drive it for a while and then i check it on cold engine shows in the middle +-
Old May 13, 2025 | 03:56 PM
W205C43PFL's Avatar
All good, it happens, don't worry about it.
As for checking engine oil, well, the oil has to drain back to the pan : )
Old May 13, 2025 | 03:58 PM
W205C43PFL's Avatar
It takes time : )
