C450/C43 AMG
Rapid ticking in line with throttle C43.
Old Apr 17, 2026 | 10:39 AM
W205C43PFL's Avatar
Calling two forum members as well although they don't frequent the forums anymore so not sure if they will join the conversation: @TwoC400s @MatthewJ
Old Apr 17, 2026 | 12:04 PM
SpizzleKicks's Avatar
C43
I will need to check my car next week, what is the condition of all your belts?
We already have all the M276 experts here including but not limited to @CaliBenzDriver Although we are missing @S-Prihadi , let me Ring him up.
Couldnt say, whats best way to check condition?
Old Apr 17, 2026 | 12:26 PM
W205C43PFL's Avatar
Check the other thread linked on the belts : )
Old Apr 17, 2026 | 03:00 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
About Being Proactive...
I don't know what else can be added ?
Any chance we can get additional focused material based on inspection feedback you already got.
Use your scanner to consider engine data in various conditions to help your progress.
At 55k.Mi this is an early mileage engine... the best you can do is to keep all its lubricants CLEAN on short schedule. When you extend intervals, it simply cost additional repairs.
Old Apr 17, 2026 | 03:36 PM
W205C43PFL's Avatar
Related? https://mbworld.org/forums/c-class-w...e-flapers.html
Old Apr 17, 2026 | 04:40 PM
C43
can certainly hear the same type of tick. WHAT THE HELL IS IT? 😂
Old Apr 17, 2026 | 04:41 PM
  #32
C43
Oil now done every 5k, transmission and AWD system oils done at purchase 54k. Turbo solenoid and actuator done to.
Old Apr 17, 2026 | 04:47 PM
  #33
this proactive maintenance is the best towards good ownership.
I dont know if this was mentioned earlier:
check the vacuum pump tiny silicone check-valve that feeds wastegate control .
Turbo owners have started modifying this failure point with longer lasting check-valve.
Old Apr 17, 2026 | 04:53 PM
  #34
W205C43PFL's Avatar
Good question : ( I am curious why both of you and the other forum member have this noise.
Old Apr 18, 2026 | 03:10 AM
  #35
C43
Did that myself a month or so back after reading about it on this very forum! Boost now holds properly.
Old May 20, 2026 | 12:48 PM
  #36
bourbenz's Avatar
unreliable robin
Do you know the MB part number? Also I've heard there's a Volvo part number that might be better? Thanks!
Old May 20, 2026 | 12:50 PM
  #37
W205C43PFL's Avatar
Here is the volvo part https://mbworld.org/forums/w212-amg/...ve-repair.html
Old May 20, 2026 | 12:51 PM
  #38
bourbenz's Avatar
unreliable robin
Crazy fast reply time, thank you!!
  #39
W205C43PFL's Avatar
You're most welcome
Old May 20, 2026 | 12:54 PM
  #40
W205C43PFL's Avatar
You can read the entire thread but this is the exact post #65 https://mbworld.org/forums/w212-amg/...ml#post9007808
