Sub Frame Severe Corrosion
The video shows corrosion and cracks along the subframe on both sides. The service report states, "completely broken right-side rear subframe and the left side is also showing signs of imminent failure".
Additionally, they are recommending the following:
Repair or replacement of the rear subframe.
Repair or replacement of the rear flex disc due to large tears.
Reseal of the transfer case to address oil leaks.
Replacement of the pinion oil seal to address oil leak.
Reseal of the upper timing case to address oil leak.
Replacement of the transmission oil pan gasket and transmission service.
Reseal of the cam covers to address oil leaks.
I have been advised by my service rep that the 2016 C450 is not covered by the recall or warranty.
NEED HELP AND SUGGESTIONS
I was gonna sell my 2013 Sonata that has 60k miles on it when I got my c43. They wanted like 5k for it... Pshh now its my winter beater. Chicago weather is brutal.
That sucks with all the oil leaks. I think they are well known for our cars. Go to a reputable euro mechanic and get it all serviced if you want it to last.
I do live in the DC area so salt could be a factor but still think it should be covered as a defect.
I found a fantastic new independent in the Westminster Md area if you are interested…though not cheap, but cheaper than a dealer. Lmk
or if you are closer to modern masters, hit them up
