C450/C43 AMG
Problem c450 help
Old May 2, 2026 | 06:08 PM
guillelrd's Avatar
C450
Problem c450 help
I’m having a problem with my Mercedes C450 AMG. The car used to run fine, but for some time now, when I lift off the accelerator, there’s a noise coming from the left side of the engine, as if something were loose. At the workshop they told me it’s something related to the turbo — the linkage/rods — and that the turbo needs to be replaced.
Also, when I try to do a 0–100 launch, the car goes into limp mode and loses power. We even tried changing the tune/remap, but it still does the same thing. At this point I don’t know what else to do.
And to make matters worse, we changed the water pump and the thermostat, but sometimes the oil temperature and coolant temperature drop, and it takes a while for them to stabilize.
The car pulls well and accelerates strongly during normal driving. It regains speed without any problem. The issue only happens when I try to use launch control.
I feel really frustrated. I keep replacing parts, but we still can’t figure out what the problem is. I’m from Spain.
Old May 2, 2026 | 06:34 PM
W205C43PFL's Avatar
need to hear a recording of the sound and know what code is stored in the computer.
Old May 3, 2026 | 07:58 AM
W205C43PFL's Avatar
Forgot to ask, how is the condition of the motor mounts?
Old May 3, 2026 | 08:00 AM
W205C43PFL's Avatar
As always a difficult question requires a person with expertise @CaliBenzDriver
Old May 3, 2026 | 09:27 AM
guillelrd's Avatar
C450
This is the error I get when I try to do a standing start. I turn the car off and on again, and then it runs fine. It’s been doing this for a while now, whereas before my times were around 4 seconds.
Old May 3, 2026 | 01:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
tuned 276 racing
ok based on what we got... direct OP to :
  • inspect vacuum pump check-valve.
  • empty oil from wastegate diaphragms
Old May 3, 2026 | 03:05 PM
W205C43PFL's Avatar
OP, let us know the results.
guillelrd's Avatar
C450
and that error I get when I try to launch
I'll look into changing that valve. It's quite cheap and I'll do it myself at home and see how it goes…
Old May 3, 2026 | 03:06 PM
W205C43PFL's Avatar
Is it some sort of rattle sound?
Old May 3, 2026 | 03:13 PM
guillelrd's Avatar
C450
I’ll try what you suggested. The car currently has 166,000 km on it, and until recently it hadn’t caused any problems at all. I don’t cut corners when it comes to maintenance. I’ll keep you updated, and thanks a lot.
Old May 3, 2026 | 04:15 PM
W205C43PFL's Avatar
Sorry for the confusion but you quoted the wrong person, all credits goes to forum member CaliBenzDriver.
Old May 3, 2026 | 04:16 PM
W205C43PFL's Avatar
Thanks forum member CaliBenzDriver for the suggestion and for chiming in, hopefully that helps OP.
Old May 3, 2026 | 04:19 PM
W205C43PFL's Avatar
As for the check valve:
https://mbworld.org/forums/w212-amg/...ve-repair.html
Have a look at this as well:
https://mbworld.org/forums/e-class-c...e-upgrade.html
As for buying a check valve directly from pump manufacturer https://klifex.com/mercedes-vacuum-p...365-2762300265
