C63 AMG (W204) 2008 - 2015
Owned the C63 for 1 Week - CHK Engine!?
Old 08-18-2008, 03:42 PM
UGOTMOPPED's Avatar
11' R8 - 11' RR Sport
Already..this crap...Picked up the car last Monday..did normal cruising..driving and etc....Have about 500 miles on it..Check engine light comes on yesterday (Sunday)...so I'm like..WTF..drop it off at dealer today...they call me and say "Bad News"....One of the particular vacuum hoses came off one of the intakes...we need to special order the part from Germany...fastest we can get it is around Friday....
1 week owning the car, 2nd week in the dealer, 3rd week i'll be away on vacation...what a way to spend my first month's payment...
Old 08-18-2008, 03:46 PM
shaker's Avatar
2009 C63
CEL at 1300 Miles
My check engine light came on yesterday as well. I will be leaving it with the dealer on Wednesday. would have been today but I needed a loaner car and Wed was the first day they had available for a loaner. Going to get engine and differential oil changed at the same time. Will let everyone know why the CEL.
Old 08-18-2008, 03:59 PM
Glock Guru's Avatar
Steel Gray 09' C63 AMG
So much for "hand built" quality control.
UGOTMOPPED's Avatar
crazy they don't have this hose/line in stock anywhere..or from any other dealer in the US..the 6.3 engine has been in the states for sometime...so upsetting..
Old 08-18-2008, 04:34 PM
YellowJacket's Avatar
2014 E63
Sorry to hear that. This is the 2nd thread about check engine lights coming on early after purchase.
Old 08-18-2008, 04:36 PM
MHP
MHP's Avatar
'09 C63 AMG
At least your ESP works.
Old 08-18-2008, 05:02 PM
Glock Guru's Avatar
Should I make my appointment with my dealer now?
Old 08-18-2008, 06:28 PM
bigbodybeeenz's Avatar
bike
I've had the same issue. Currently getting a new ecu installed in my c63
https://mbworld.org/forums/c63-amg-w204/255328-so-i-got-my-white-sahara-c63.html
Light kept coming on. Something about the car self-testing for emissions, and not sending the right voltage to a certain part (Purge Valve) Everything else checked out ok so now I am getting a new ECU that will properly self test the emissions system.
Old 08-18-2008, 06:29 PM
UGOTMOPPED's Avatar
same issue..why an ecu? they said a vacuum line on one of the intakes split or something..I was like, and you don't have another laying around?...
Old 08-18-2008, 07:29 PM
Glock Guru's Avatar
https://mbworld.org/forums/showthread.php?t=255328
New ECU? I guess I should wait till I put a few thousand miles on mine before I start with the upgrades.
Old 08-18-2008, 11:12 PM
nrgy's Avatar
AMG GT-R
I havn't had any issues so far with my car after 2000 mi. My brother, who just picked up his C63 about 1-1/2 weeks ago had as CEL after 50 mi. Turned out to be the cam sensor that was discussed here before.
Old 08-19-2008, 11:28 AM
Balz's Avatar
C63, LR3
Sorry to hear...mine has been OK so far...1100 miles...but I'm getting worried now...hope they get it worked out for you...
Old 08-19-2008, 11:44 AM
MNL ICE's Avatar
08 C63 AMG
welcome to the club
ARC101's Avatar
2008 C63
5,000 miles and other then some oil and tires the car has been great. No motor related issues (know on wood). The weather stip on the front grill pushed out and it was replaced without question. I also had the sun roof fixed. It needed to be reprogramed.
Old 08-19-2008, 11:49 AM
Stradale's Avatar
'04 WRX STi / '01 S2000
Sounds like normal, harmless annoyances from a first model year run. I have not heard of any engine failures or anything on this car.
Old 08-20-2008, 09:35 PM
shaker's Avatar
2009 C63
Just got my car back from the dealer tonight after leaving it with them for the CHK Engine Light and getting differential and engine oil changed at 1500 miles.
The error code for the CEL was 1085 which is the code for a purge leak. The tech performed a quick test and noted on pressure drop at .074 HPA however the spec is tolerated up to .157HPA, so it was well with spec. the correction was nopted as follows: Found NEC to program ME control unit as per SDS guided test, cleared codes and retested to verify the repair and system passed without any purge errors. So let's hope that will be the end of that.
Old 08-20-2008, 10:08 PM
UGOTMOPPED's Avatar
congrats..I am sure those days with out your beast was upsetting.
Old 08-20-2008, 10:32 PM
shaker's Avatar
2009 C63
Likewise! Are you still on schedule to get yours back on the road on Friday?
Old 08-21-2008, 08:19 PM
itwepon2's Avatar
C63 AMG
I had the CEL and took it in to the dealer. The Service Manager listened to it and told me "not to worry." Sure enough, it never came back on. It was not hooked up to anything, they told me to come back to the dealer if it kept acting up for the next week. It's been perfect ever since. Best advice is to ignore it for a few days and it will likely go away. The CEL is not a serious thing, according to my dealer.
Old 08-21-2008, 08:32 PM
shaker's Avatar
2009 C63
what error message did you get. I would never ignore it. The dealer NEEDS to let you know why the CEL came on for.... if your dealer only cleared the CEL without telling you what the error was then I would change dealerships ASAP.... a firmware reload was needed for mine and it was per a note regarding these engines.
Old 08-21-2008, 10:10 PM
itwepon2's Avatar
C63 AMG
They never hooked it up to check. So, no clue what "code" it was complaining about. They never touched it, aside from the Service Manager listening to the engine... I was pretty mad when I left because they were too busy to look at it. But, it never came back on again, so I forgave them.
Old 08-21-2008, 10:17 PM
UGOTMOPPED's Avatar
Let's see...everything is depending on if the part comes in tomorrow.
Old 08-21-2008, 10:18 PM
shaker's Avatar
2009 C63
I had the same problem with the dealer being to busy to check it out right away. I reported the issue on Monday and could only get an appointment on Wednesday because I needed a loaner and that was the first available day. I did not notice any performance change nor any different engine sound so they told me that it was probably not a MAJOR issue. But my dealer would rather be safe than sorry than just resetting the CEL.
Old 08-22-2008, 01:30 AM
Arctic White's Avatar
09 C63 (Coming Soon)
Check engine light? No way, whats new?
This is completely unheard of
Old 08-24-2008, 02:34 AM
passcheco
Guest
Posts: n/a
09 Engine Lt on
Hi this is my first post, Today with 273 miles on my C63 I was just driving along and then bang she back fired twice and bingo engine light on. Any one with this issue on the 09's?
Quick Reply: Owned the C63 for 1 Week - CHK Engine!?
