Whats faster e55 stock or c63
E55 because of their ability to utilize the ESP for launching since they make so much low end torque. ESP causes the 6.2 to bog and without a PD blower it falls out of it's rather fat powerband.
With that being said I still think we're going to see 11 second tune/DR only C63s by the fall.
E63 P30, CL500 Sport
A stock E55 will easily dispatch a stock C63. The E55 have been averaging 12.30s to 12.40s, but almost all runs that were attempted in optimum weather conditions resulted in 11.80s to 11.90s runs bone stock.
Now once the C63 gets ECU-Tuned, then the game will definitely be more leveled. But then again, you're back at comparing stock to modified.
Andy
rolling from 35 c63 in 2nd gear i pulled away from the e55 about 1 car and pulling to 100mph. cant wait to put 275 in the rear of my car ohhhhhhhhh im ganna feel bad what i do to this e55
I have both but havn't pitted them up against each other. I will say the E55 feels quicker though; its punches you in the back more and the surge is much more understated then the C63's loud wail.
Not to say the C63 doesn't have a kick to it, but I can definatley tell the E55 has a bigger punch. I would expect with something like Kleeman tune and headers, the C63 wouldn't have trouble taking the E55, and with similar torque numbers have that kick the E55 has.
997TT, C63(delivered what a car!) ,M3 , WRX , A3
i think from a roll, the C63 can beat the E55... for simple things...
both cars have almost the same power(+25hp to E55), the E55 weights MORE, and have an OLD 5 gearbox...
because its shorter ratios the C63 will have better acceleration in higher speeds....
2009 C63 AMG / 2009 Nissan GT-R / 1988 Ferrari 328 / 1977 Maserati Bora
They should be very close
I have a C63 and have test driven an E55, but have no experience in anything head-to-head.
I did do some internet research across "Road and Track", "Car and Driver" and "MotorTrend". The numbers for those magazines quote very similar 1/4mile (12.5sec) and 0-60 (4.3sec) and 0-100 (9.7sec) average times. There were variances, but neither car was consistently faster.
This has been discussed to death over in the E55/E63 section of the board. The E55 dynos are identical to the S/SL/CL 55 dynos. All 55 kompressor motors are putting down 410 to 430 wheel hp, which equates to about 500 crank hp. So the E55 has a 50 more hp and 75 to 85 more torque. Of course, it also most of this torque available very early and very quickly.
1 Post
04 w211 E55
from rolling at 25mph c63 with bold tires spining 1st and 2nd i statrd pulling on him at about 90mph and about 145mph i was rite neck to neck .
benz and bimmer
E55 is gonna be faster, it traps higher aswell. it def. FEELS fast. i havent raced mine together yet, but i did race my 335i and C63, the 335i has a mild tune and intake. was neck and neck to 100mph where we stoped, same results 3 times in a row. the E55 higher trap should show about a 2 car win for it, esp at those speeds
Thanks!
On our E63s, we don't have 3 settings for the ESP like you guys do in the C63; we only have on and off. I always have ESP off when I'm at the drag strip. As for the transmission mode, most of the time I leave the car in Sport mode. However, I have tested M mode before and if you can master the shifts perfectly, it does yield faster results. I've measured this with 2 different devices, and both 0-90 mph results were slightly faster in M mode than in S mode. However, in M mode, there is a varying delay that occurs from the time you hit the paddle to the time the car actually shifts. The delay is not always the same, which makes it EXTREMELY DIFFICULT to master the shifts.
Thanks for the reply. I feel you on the shift delay when in manual mode, the inconsistancy (in addition to the delay) drives me crazy. Hopefully this is something we'll be able to remedy with our ECU tuning. Worst case scenario I'd like to see manual type shift quickness/firmness (or more) while letting the car shift itself to yield the quickest and most consistant results--that I'm certain we can do.
Thanks. I tried to google your shop and didn't find anything under "MHP".
The site is significantly behind our actual development; unfortunately I'm not very good at designing/building websites and my developer is a slackass. As soon as we have C63 data (track/dyno) I'll make sure it gets up asap.
Andy
you mean.. the DELAY is different per GEAR , or is JUST ALEATORY? sometimes in 1st 0,2 sec sometimes 1st 0,4 sec LIKE THIS?
OR each GEAR HAS IT OWN DELAY , and always the same per gear?
sorry bad english i dont know if you got the idea....
