engine oil temp
engine oil temp
I tried the search option but didnt find anything, what should a c63 engine temp be at during normal conditions and spirited driving?
during normal conditions my car sits at roughly 107c (not fahrinheit)
during spirited conditions ive seen it go as high as 117c
thanks
h
thanks
h
That is very high for coolant, normal for oil.
ok but that still doesnt answer my question.
My engine temps are fine, it doesnt get hotter then 93c which is ok.
But engine OIL temps is what i am curious about.
thanks
h
thanks
h
how do u change the setting to reflect Celsius?![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
05' 997 C2S cabriolet; 08' white C63
When I push it a little bit, it stays above 120C or 248F.
I guess this is normal for C63, but not so when you compare it with other engine---it's a bit hotter.
P.S. My friend had seen 150 celsius one time when he pushed his C63 really hard.
2013 ML63 AMG PP
no worries....
The problem with this 'new' info on the water and oil temperatures, unless you had other cars showing you the oil temp, is that you were used to the normal 80 degrees Celcius water temp that is shown on all other Mercedes-Benzes. Therefore, it feels weird to see the oil temp that high. I had gotten used to associating the water temp with oil and engine temps.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
What's even more interesting is when you drive the car first thing in the day. The water temp reaches it's operating temp much faster than the oil. I used to drive my previous cars much more gently until after the water temp reached approx 80c but with this new discovery, I will now wait longer just as I am doing with the C63.
2006 BMW 330i, 2009 C63
Damn, I guess I am not pushing my car at all. The highest I have seen is 105 C. The regular temp I see during normal driving is 99 - 100 C.
George
George
gmw, my 1st time i have ever owned a benz. I have just ran the engine in, and did an oil & filter change, so i would like to know if my operating temps were correct.
Thanks for the info guys.
