How do you get the best start off the line?
Question is that I'm getting a lot of wheel spin and then the RPM lowers a bit at launch. The tranny is set to Sports mode and ESP set to ESP-Sports. I think that with so much wheel spin off the line, the ESP is kicking in which causes the RPM to drop a bit but I'm not sure. I also think that it might be because I don't have the Limited Slip Differencial option.
Can anyone here recommend the best way to launch the car off the line to get the best 0-100km (0-60mph) time? I prefer to keep the Tranny in Sports mode since I believe that the computer will know better to shift at the most optimal time for the quickest acceleration vs me doing it in Manual mode.
Thanks.
2- don't stomp throttle like you're killing a roach - use a progressively increasing rate of throttle/foot pressure application so that in the first .5 seconds you are pushing gas at a slow but increasing rate, then keep increasing that rate until you are flooring it at about 1 to 1.5 seconds
I concur with your and Tyanger's comments. ESP will apply the brakes and reduce engine power to keep the rear wheels from spinning. As a result any launch that's hard enough to trigger ESP will slow you down. Rolling into the throttle so that you are just a bit short of engaging ESP will give you the fastest launch.
not everything will apply but there should still be some useful info there.
https://mbworld.org/forums/w211-amg/...acing-how.html
although u change to a wider tire, it still gona spins, and btw, if u dont want to change the overall length/perimeter of the tire which will affect the miles per galon. then the tire is gona be 295 rear, 265 front, it's too wide, u gona have to get another rim and also MAY not fit or affect the performance. U gona have to find it out first.
2ndly, best launch for automatic is always hold on brake and then throttle rev to over 3000rpm if the car allows, then release brake fast.
although u change to a wider tire, it still gona spins, and btw, if u dont want to change to overall length/perimeter of the tire which will affect the miles per galon. then the tire is gona be 295 rear, 265 front, it's too wide, u gona have to get another rim and also MAY not fit or affect the performance. U gona have to find it out first.
2ndly, best launch for automatic is always hold on brake and throttle rev to over 3000rpm if the car allows, then release brake fast.
Turn off the ESP and try 1300-1500 rpm and roll on the power. At a recent track day we had four BS and C63 at WSIR and we tried all kinds of launch techniques and that seemed to get the best launch. Granted we were using the front straight and didn't have the same prep you would at a drag strip.
Jimmy
Anyway, try losing a few psi all round. It will help with the traction more than going wider tires.
Alternatively, drag radials as others have stated.
Jimmy
So, turn off ESP, hold down the brakes, rev to 1300-1500rpm, release the brakes, and then slowly floor it, right? What I mean by slowly flooring it is that instead of just stomping on the gas all the way, press down to the end moderately...
I tried ESP Sport but it seems turning off ESP is needed so that the engine doesn't brake with ESP kicking in.
