C63 AMG (W204) 2008 - 2015
Mobil 1 5W-40 Synthetic (non diesel)
Old May 4, 2009 | 02:44 PM
hawtheric1's Avatar
2009 C63 AMG
All I can find is the diesel version. Plenty of 0W-40 but no 5W-40 other than diesel.
Any recommendations on where to buy the 5W-40?
Hawth
Old May 4, 2009 | 03:51 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
If you find a place, please let me know too... i have only been able to find 0W-40 at Walmart.
Old May 4, 2009 | 04:04 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
There you go....
http://avlube.com/mo1espfom5wc.html
Old May 4, 2009 | 04:41 PM
hawtheric1's Avatar
2009 C63 AMG
Originally Posted by MB_Forever
Shwing!
Thanks MB_Forever. Good lookin' out.
Hawth
Old May 4, 2009 | 04:50 PM
MB_Forever's Avatar
Originally Posted by hawtheric1
Shwing!
Hawth
No problem.....
By the way, most Mercedes-Benz dealers carry that oil now. That oil used to be hard to find at first, but a few months ago when I called a couple of MB dealerships here in California, they both carried it.
Old May 4, 2009 | 05:25 PM
gsrjc's Avatar
yeah, thanks man.
Old May 4, 2009 | 06:25 PM
hawtheric1's Avatar
2009 C63 AMG
No problem.....
My dealer said they only carry the 100 gallon tanks so SOL on that.
I did get another tip that Carquest carries that grade so may be able to get it locally versus online.
Thanks again,
Hawth
Old Nov 29, 2010 | 11:30 AM
jctevere's Avatar
2012 C250 Coupe
If you read the description, that oil is made for diesels also with the ESP or Emission System Protection lubrication. We need 229.5 spec, not 229.51. Has ANYONE found where we can get 5w-40 from that doesn't have ESP? I am beginning to think that it doesn't exists and that I should just use 0w-40...
Anyone know what the difference is anyway?
Old Nov 29, 2010 | 11:51 AM
Raleighc63's Avatar
2009 C63
My dealer has 5w/40 for $5.86 after tax per qt.
Old Nov 29, 2010 | 05:07 PM
ATL_MB's Avatar
2010 C63
I don't think that there is such a thing as 5W-40 non-ESP. However, either the 229.5 or 229.51 spec works -- I prefer and use the 229.5 (non-ESP) 0W-40. Mainly b/c you can get it just about anywhere but also b/c the ESP oil is designed to work with either diesel or gasoline engines, meaning it is more of a compromise than the original non-ESP formula. There are several differences but the only one I remember is that the ESP is a low-ash oil (I don't know why that matters) and formulated to work with desiel engine emissions systems (the new particulate filters, I believe).
Probably makes little or no difference in performance or protection, but using the non-ESP makes me rest easier (perception is reality, no?).
Old Jan 3, 2011 | 09:58 PM
PatSC23's Avatar
2009 C63
its been so long since I ordered oil - is it 0w 40 or 5w 40?
Old Jan 4, 2011 | 04:36 AM
newguy2008's Avatar
CLK 55 ///AMG Cabrio, ML63 ///AMG
5w40.
Old Jan 4, 2011 | 11:25 AM
Mort's Avatar
According to my owner's manual it is either.
0W40 Mobil 1 is easier to find and MB Spec 229.5
5W40 ESP Formula M Mobil 1 is for Diesel applications (and gas?) and is MB Spec 229.51.
What does this mean in reality? I am sure I don't know exactly.
Either oil viscosity is specified for all ambient temperature ranges.
Just to throw a snag into it the Mobil 1 site http://www.mobiloil.com/usa-english/....aspx?option=2 now specifies Mobil 1 ESP Formula 5W-30 to MB Spec 229.31 or 229.51. This oil is only specified for ambient temperatures up to 86*F / 30*C.
I am going to use Mobil 1 0W-40 as it suits our climate and has better cold start protection due to the better flow rates at colder temperatures.
They couldn't make it any more confusing if they tried.
My SA says that they have been told, by MB Canada, to use Mobil 1 5W-30 in all AMG applications. Not positive but think this must be the ESP Formula.
Old Jan 4, 2011 | 01:15 PM
PatSC23's Avatar
2009 C63
yeah its very annoying to say the least - I dont know much about oil for cars, and at the rate this car burns it Im paranoid Im putting the wrong stuff in. From the sounds of it 5W40 and 0W 40 are both ok. For some reason Im leaning toward 0w-40, maybe because the diesel thing is throwing me off.
Old Jan 4, 2011 | 06:21 PM
Mort's Avatar
If you drive in the winter in NJ, I think the 0W-40 is the better choice anyway and it at least meets the MB Spec 229.5 for our cars.
I also think the 5W-30 may not be the best for your summer temperatures if you get over 90*F for an extended period.
I am not impressed that the 5W-40 only seems to be built for diesel either.
Old Jan 5, 2011 | 10:21 AM
PatSC23's Avatar
2009 C63
Cool - thanks for the input. Where do u guys order from?
Old Jan 5, 2011 | 10:37 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
It should be noted that these are the only 2 oils that maintain the M156 Warranty. This is not a statement meant to mean other oils would be fine or better.
You can get the Mobil1 5W-40 at Pep Boys now, although if you can get this from the dealer for <$6 I am floored.
I usually get the Mobil1 0W-40 at Walmart.
Old Jan 5, 2011 | 10:46 AM
Mort's Avatar
I just saw in another thread that the Spec list has been updated and now includes 5W-40 Formula M Mobil 1. You can check it out here:
http://bevo.mercedes-benz.com/bevoli...nt_action=show
Old Jan 6, 2011 | 09:59 AM
OzC36's Avatar
Silver 1996 C36
Yes but it needs to be read in conjunction with Spec 223.2 which has restrictions on specific engines and where and what oil can actually be used...
http://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
Old Jan 6, 2011 | 05:33 PM
Mort's Avatar
Thanks and what that states has already been covered.
