First time at the track. brutal.
It was pretty cold. So traction was brutal. Only plus 12C.
Did 4 runs, best I could hit was 13.6 at 109mph, 60 was 2.332
First run, i forgot ESP on. That killed it huge.
Second run, rev's at 1800rpm ish, floored it in S mode. Spun all first and 2nd, went sideways some.
Third run, tried to feather the throttle, spun off the line, let off, it shifted to 2nd, then pinned it again and downshifted to 1st and took off.
Fourth run, ESP off and M mode. Tried to feather the throttle only slight wheel spin, but hit the rev limiter off first gear. got 13.6 on this run.
Tires are too hard I think, they have a 320 treadwear, I need something sticky....
I am looking at the Toyo proxes R888, but they dont have the right size. the closest I can find is, 295/30R19 will that fit on the 19inch AMG rims? 275 is tight already.
I must practice with the manual mode some more. I drive in S mode with ESP off all day, so I am not too familiar with the M mode shifting..
What's everyone elses set up at the track??
1. ESP stays off for the entire process(staging & racing)
2. Use M mode for the burnout.....tires need the heat don't hold back
3. Tranny in sport mode for the pass which is quicker than M mode and you wont bang the limiter
4. 1500 rpm at launch and throttle up according to traction
I have plenty of passes on street tires and drag radials. I have Proxy 888"s on a spare set of wheels and they will spin under a full throttle launch unless the conditions and track are perfect. Dad's C63 is running MT's and he is able to launch by going full throttle then releasing the brake. The tires hook and he leaps out of the box which is a huge advantage. My best time was running street tires on the last cool night that we will see this year and I know that a banzai launch with MT's would have shaved 2-3 tenths. Now that we are back to 80+ degree evenings I am done till fall.
I think the best way is M mode, just getting good at shifting when the redlight comes on is the key. Then you can feather the throttle without it shifting to second.
Another idea I had was keep it in S mode, but manually shift to 1st, that way it will hold every gear to red line and shift perfect but only at red line.
Now all I got to do is find some sticky tires that will fit my rims.
I keep recommending the Bridgestone RE11 tires to people. I've read nothing but excellent reviews from this tire...it is a very high performance street tire, I think the next best thing to a R compound.
Where is this track? Obviously at altitude?
